Re: Thermoquad secondary jet source
[Re: Seth_Jones]
#1047112
08/04/11 12:49 PM
08/04/11 12:49 PM
dogdays
[Re: Seth_Jones]
#1047116
08/04/11 05:17 PM
08/04/11 05:17 PM
Posts: 21 Ontario, Canada
krep76
Ontario, Canada
I'm going through the same thing at the moment. I've got the primaries where I want them with 95's, but with the 137's secondaries, WOT is in the high 10's. I was questioning the secondary door spring tension but haven't had a chance to check it. Have you played around with that to see if it makes any difference?
I found it strange that these things would come stock with even bigger jets that the 137's if they run that rich.
[Re: Seth_Jones]
#1047118
08/04/11 08:12 PM
08/04/11 08:12 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
depending on what carb you have maybe a secondary jet from a 318 TQ would be better?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Seth_Jones]
#1047121
08/05/11 01:07 AM
08/05/11 01:07 AM
DaytonaTurbo
Manitoba, Canada
My 850 is rich at WOT with a 143 jet so I put a 137 in it(leanest I had) and the AFR went from 10 to 11.5 while my cruise AFR is lean.I would like to get some secondary jets in the 120 range.
Is your secondary air door adjusted to open all the way?
Why not just fill yours in and drill them to what ever size you want?
I have read someone else on here suggesting to fill them with sodder, then drill them out.
[Re: Seth_Jones]
#1047127
08/05/11 04:01 PM
08/05/11 04:01 PM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Air door is adjusted all the way open
The air-door should NEVER be all the way open.
[Re: dOc !]
#1047129
08/05/11 04:17 PM
08/05/11 04:17 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
There is a spec that indicates what the correct open position is (usually listed for convenience in the rebuild kit instructions). Under wide open throttle the air door should be open to this position. I use a different setting than the factory spec (a little tighter) that I have picked up some ET but the OEM spec should be fine in this case.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: dOc !]
#1047130
08/05/11 04:37 PM
08/05/11 04:37 PM
Posts: 1,551 Marion,Indiana
Seth_Jones
Marion,Indiana
I believe its at.500 right now but I have had it adjusted to where its almost shut and everywhere in-between with no change in WOT AFR readings.
