WHAT SIZE WHEELS+TIRES on F-body #1046828
08/03/11 07:28 PM
08/03/11 07:28 PM
PA
W
w7smallblock Offline OP
W
PA
What size wheels and tires are you running? Please post pictures and list wheel width ,backspace and tire sizes. I'm thinking I'm going with 8"wheel on the back 4.5" backspace with 275/60/15 and 7" wheel with 4" backspace with 245/60/15 on the front.
Here's how the car looks now with 205/70/14 they have to go.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: w7smallblock] #1046829
08/03/11 07:35 PM
08/03/11 07:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
very sweet ride dude! 60's are alot of meat to squeeze on a 7" rim and put up front. i would have serious doubts about your turning radius
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: mikemee1331] #1046830
08/04/11 02:20 PM
08/04/11 02:20 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
M body, same chassis as an F, 255/50R17 on all 4 corners, with 17x8" rims and 5" backspace....
2017 Grand Cherokee Overland
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: w7smallblock] #1046831
08/05/11 10:35 AM
08/05/11 10:35 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I had 295/65x15 rear and 205/70x15 on the front of my F body. That much rear tire required rolling the fender lip and clearencing the wheel well righ tin front where the rear set belt mount was located. I also had converted to a B body 8.75 housing, which is a 1/4" wider per side than teh stock F body unit. Looked like a vintage pro stock car that way.
Previously I had 28x9x15 slicks, which are pretty darn close to 275/60. Fit great with a 15x8 rim with 4.5 backspace and require no body mods to fit.
Up front I'd recommend a 235/60 instead of the 245. Easier to find and cheaper to get while only giving up 10mm in width. these would work nice with your 15x7 plan.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: TC@HP2] #1046832
08/06/11 04:53 AM
08/06/11 04:53 AM
PA
W
W
PA
Thanks for the info. I wanted the 245 becuase it was taller.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: w7smallblock] #1046833
08/06/11 10:44 AM
08/06/11 10:44 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The 245/60-15 will fit the front with no problem. With a little rework 325/50-15 will fit under a lowered rear as well. Requires some welding of the fender wells behind the rear seat and moving the springs inward . I used all stock parts. Axle choice depends on wheel off set.
Doug
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: mikemee1331] #1046834
08/06/11 10:57 AM
08/06/11 10:57 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
How old are you? 60's indeed. I suggest you learn up on MODERN tire sizing.
Don't be the exception.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: w7smallblock] #1046835
08/06/11 11:13 AM
08/06/11 11:13 AM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
Here is a M-body coupe comparison, but as highlighted already, it's almost the same thing:
1) FRONT
2) REAR
3) REAR SIDE
Here is the tire sizing:
WHEELS & TIRES BRAND SIZE RIM WIDTH SPEC MEASURED WIDTH TREAD WIDTH DIAMETER MAX LOAD REVS
FRONT Yokohama Avid S/T 235/60R15 98T 6.5 - 8.5 7 9.5 7.4 26.1 1642@35 796
REAR Nitto NT555R 275/60R15 107V 7.5 - 9.5 8 11.1 8.5 27.76 2150@44 748
The rims are Centerline AutoDrag III, part numbers:
175804545
175705545
...basically 15x7 (front) and 15.8 (rear)
If I had a chance to do something different I would have gone with a slightly more offset on the rear rim...maybe another 1/2-1" more...that would have stuffed the tire completely into the wheel well as opposed to the sidewall being just even with the edge of the body line.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: Supercuda] #1046836
08/06/11 11:46 AM
08/06/11 11:46 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Talk about a trick question....OK lets start witht he oem 8 inch sc rims 15X8x4.5bs.
I myself like a bfg 275/60/15 rears I really dont like the sc 8 inch in the fronts so I went with the 8s on the rear and the same style 7 inch on the front with the 235/60/15.
The 8 inch sc rims work on the front but you need to watch your alignment as if its off a bit and your using outter rim weight it will shave them, so if using 8 inch 4.5 on the front use stickon inside weights.
On the R/T with the alterktion nothing on the fronts apply but the rear I run 10 inch rims for both 10.5 and 12.5 slicks or 12.5 bias.
The main pinch point is the most forward inside lil "box" where the back seat belt assembly bolts to, this box can be cut out and flat stock put there and still bolt your assembly back in.
Also in that front area the seam where the quarter panal and the wheel well meet is a approx a 1/2 to 3/4 lip, you can cut it every six inches and roll it inside and weld it up and gain clearence.
To make mine more difficult is ive a no mopar width dana, wider then a b but more narrow then an e but 12.5 slicks fit well which would be a 315 drag radial.
Really its limitless and up to your tastes, jegs is very good at listing the tread width, sidewall width, ect and with some smart thought and alot of measuring you can hit it right the first time.
What I do is for instance use a rim I know like a 8 inch 4.5 bs sc rim as well as like a 275 60 15 that jegs also lists the specs to and use that for a base to go off of.
Ive been lucky enough to be anal enough and spend enough time moching up and measuring and remeasuring ive never had to list a tire or rim due to lack of fitment.
If anyone would like pics of the mods the the front box or rolling th iner lip flush to the frame rail I can post them.
This is probably more confusing then helpful...
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: quick77rt ] #1046837
08/06/11 11:57 AM
08/06/11 11:57 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
A 28 12.5 in an oem wheel well, monos in stock location, rear spring sliders. Nothing ever rubs.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: quick77rt ] #1046838
08/06/11 12:12 PM
08/06/11 12:12 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Here is the 275/60/15 on 8 inch 4.5 and the 235/60/15 on 7 inch 4.5bs.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: quick77rt ] #1046839
08/06/11 12:48 PM
08/06/11 12:48 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I know it's not a F body, but the dimensions are similar. I have 255/60's on the front and 275/60's on the rear of my 80 Mirada on cop wheels.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: TC@HP2] #1046840
08/06/11 12:50 PM
08/06/11 12:50 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Rear 3/4 view of the whole car.
Rear view of 295/65.
Space to wheel lip with 295, 15x8 w/ 45 backspace and B body 8.75 housing.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: TC@HP2] #1046841
08/06/11 01:05 PM
08/06/11 01:05 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
'79 Aspen
front 245/60/15 on 7"/4.25"bs Rallye
rear 275/60/15 0n 8"/4.5"bs Rallye
The rear wheelwell lip would rub the outside sidewall on a big dip. I think if the lips were rolled up they wouldn't rub, but before I could try it, the right front tire blew and I had to go back to my 14" tires.
I had these wheels/tires so I tried them. If I were starting from scratch, I'd go 235/60 on a 7" front, 255/60 on an 8" rear.
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: B5 Bee] #1046842
08/06/11 04:21 PM
08/06/11 04:21 PM
PA
W
W
PA
Thanks for all the pictures and tire sizes. B5 BEE your car is exactly what I was looking for.
Keep the pictures coming I like seeing these F&M bodys
Re: WHAT SIZE WHEELS+TIRES on F-body [Re: w7smallblock] #1046843
08/06/11 07:47 PM
08/06/11 07:47 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
275/60/15 on 7" wide police car wheels
and the fronts are 215/70/15s on 7" cope wheels.
