Re: 604 Predator motor on dyno Friday
[Re: Dodgem]
#1046793
08/04/11 10:17 PM
08/04/11 10:17 PM
Posts: 877 ky
68roadrunner
ky
This will be interesting!
very much so. the dyno is just for breaking it in. in car numbers, and how many passes you get before a freshen up is what we want to know....good luck.
[Re: 68roadrunner]
#1046794
08/05/11 01:03 AM
08/05/11 01:03 AM
Posts: 19,543 Las Vegas
Al_Alguire
Las Vegas
I think a lot of us want to know about this part...
[Re: camastomcat]
#1046796
08/05/11 11:34 AM
08/05/11 11:34 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
While we are waiting on the Dyno reports from that Big O'll Mopar engine. Tease us with a little info. about the dragster it is going in if you have the time....hard-tail, 4-link,wheel-base,rear gear and tires. GOOD LUCK on the dyno pull's today!!!!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: jim sciortino]
#1046799
08/06/11 12:08 AM
08/06/11 12:08 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
OK, we flogged on it all day and finally got it started around 6. The guys were supposed to leave at 5. We just fired it and ran it a little, and they didn't like the way it was running, but by that time it was 7. I told them to come back and run it Monday, get it figured out, and get some numbers then. I did get some video of it running, but don't know how to post it. What I was promised was that there would be a U-Tube video before it's done and I will give everybody here the link. I also have some pic's but need to re-size them and it's 11 right now, so I'll try that tomorrow, but it sounded real nasty to me. I'm thinking it's gonna make some serious steam. More on Monday and pics when I can get them re-sized.
[Re: camastomcat]
#1046800
08/06/11 12:18 AM
08/06/11 12:18 AM
Posts: 1,057 The Great White North
RAMM
This is the way any project that will turn out WAY better than expected tends to go--So I would say that you are looking good. Keep positive 'cuz nothing else will help a damn bit. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: camastomcat]
#1046806
08/06/11 12:52 PM
08/06/11 12:52 PM
Posts: 1,664 North Sweden
RT540
North Sweden
OK somebody needs to tell me how to post multipule pics on here. I also have a video, and would like to post that. If you can guide my antiquated mind through it, I'll post it when I get to the airport.
Multipule pics in the same post, is only possible if you have some where to host them, like a website server, there´s several places you can rent space, I have access to my company s space on a server.
Nice pics, and engine
Tom
[Re: Get-X]
#1046809
08/06/11 02:55 PM
08/06/11 02:55 PM
Posts: 627 IN
BIG BEAR
IN
Wow, surprised how long the runners are on that manifold Compare to the manifold CFE made for my hemi...
I guess the fact that the hemi has a 9" deck has something to do with it and possibly the intended rpms for the different engines as well.
WOW Wheres the Block???
Those heads are awesome
[Re: camastomcat]
#1046810
08/06/11 03:17 PM
08/06/11 03:17 PM
Posts: 614 Michigan
Get-X
I think yours is the smarter way to go. Both will be reasonably close on hp, but yours will do it more reliably and for a lot more laps before needing the maintenance mine will need way earlier. I thought about having a billet block made as I won't be hot lapped where I will run it, but am too cheap to come off of the 10k for the block. I can't wait to see what yours ends up doing on the pump both with the single and dual carbs. We're also putting together a 572" B1 engine with a Hogan s/m manifold, Fast XFI using two big Wilson throttle bodies and two dry fogger stages in a Spitzer car to run T/D and quick 8's locally. Curious to see how that plays out as well. Anyways, got my fingers crossed for you on Monday and please keep us updated.
'65 Belvedere '68 GTX '57 Dodge pickup
