First Impressions - AMD 70/71 Cuda Quarters #104602
08/14/08 01:21 AM
08/14/08 01:21 AM
California
sixpaktoogo Offline OP
California
Received my 70/71 Cuda quarters from AMD yesterday. Here are my first impressions of them (preliminary fitting):
The Good:
1) MUCH better quality of steel than Goodmark (thickness, strength, straightness, etc).
2) Top of quarter at the door is correct angle, unlike Goodmark.
3) Fit around wheel house looks good, unlike Goodmark, which had to be pushed in very hard and clamped in place, causing stress to the panel..
4) No waves on the top, at the bottom of the "C" pillar, or around the wheel opening, unlike Goodmark.
5) Fit at rocker seam is like original, unlike Goodmark.
The Bad:
1) Fit at trunk extensions (Goodmark) is poor, same as Goodmark! Driver side has the correct spacing between the holes that the valance studs go through, but the passenger side holes are 1/2 inch too close. Goodmark trunk extensions have the correct spacing. This area will take some work to make it fit correctly.
2) The contour of the panel behind the wheel at the body line, is too sharp, and the wheel lip needs to be stretched to make it fit the trunk extensions. I compared this area to my original 70 Cuda. The contour of the Goodmark trunk extensions I am using, look to be pretty close to my originals. This was also a problem area with the Goodmark quarters.
3) Wheel lip narrows too much towards the bottom, behind the wheel
4) The contour of the panel at the door edge, between the upper body line and the middle body line, is too "flat", and will need to have the edge shrunk to give it a more convex contour, in order to match that of the door.
Overall, I am much happier with these panels than the Goodmark ones I had at first!
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: sixpaktoogo] #104603
08/15/08 01:13 AM
08/15/08 01:13 AM
California
California
No other comments???
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: sixpaktoogo] #104604
08/18/08 10:17 PM
08/18/08 10:17 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
after all the leadup this is it so far?
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: sixpaktoogo] #104605
08/20/08 02:57 PM
08/20/08 02:57 PM
The Good:
The Bad:
Sounds like a decent panel.I would like to see them fit up with original Chrysler trunk extensions though instead of the Goodmark extensions.Who says the Goodmark extensions are right???
I have used repro trunk extensions on B,E and A bodies I have restored,and have never seen an accurate repro trunk extension yet.
I know AMD is coming out with "new" trunk extensions for many body styles,so lets hope they are accurate.Are the Goodmark extensions a newly developed panel-or the same panels that have been availble for the last 15 years or so ?
Re: First Impressions - AMD 70/71 Cuda Quarters #104606
08/22/08 11:22 PM
08/22/08 11:22 PM
Central Pa.
Cloned_Cuda Offline
Cloned_Cuda  Offline
Central Pa.
for the weekend.
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: Cloned_Cuda] #104607
08/23/08 08:17 PM
08/23/08 08:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Some nice detailed pics of AMD's cuda stuff being installed......take a ride over to DodgeCharger .Com......poster is lilwendal, and the post title is "wanna see my taiwian Cuda'"...its in the general section....pg3....dudes doin a nice job!, basically building his whole car with AMD's pcs
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: DAYCLONA] #104608
08/23/08 11:37 PM
08/23/08 11:37 PM
st louis metro east
cheech9898 Offline
cheech9898  Offline
st louis metro east
Dayclona,
Thanks for posting about that thread over on DodgeCharger.com . My stomach's been queezy since I placed an order to redo the whole back-end of my 74 barracuda with AMD's new metal. Seeing someone else have good results goes a long way to settle the jitters.
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: DAYCLONA] #104609
08/26/08 02:18 AM
08/26/08 02:18 AM
California
California
Quarters are NOT from AMD, but are Goodmark!
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: sixpaktoogo] #104610
08/26/08 12:27 PM
08/26/08 12:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Never said they were?........Just that there was a post of a cuda being outfitted with some AMD pcs, at least you can see how some of the aftermarket repro pcs look
Re: First Impressions - AMD 70/71 Cuda Quarters [Re: DAYCLONA] #104611
08/29/08 10:59 PM
08/29/08 10:59 PM
Central Pa.
Cloned_Cuda Offline
Cloned_Cuda  Offline
Central Pa.
