Ebody Cuda Brakes #1044902
08/01/11 01:51 PM
08/01/11 01:51 PM
west babylon, ny
ASAHEMI Offline OP
ASAHEMI  Offline OP
west babylon, ny
I sure this has been beat to death, but what is the best conversion for disc brake setup? (clone hemi cuda)
Should I use stock drum spindles or disc brake spindles? Or maybe just get the wilwood setup. Recommendation on any kits would be appreciated. Thank you.
Re: Ebody Cuda Brakes [Re: ASAHEMI] #1044903
08/01/11 09:03 PM
08/01/11 09:03 PM
11&3/4" stock slider discs up front w better aftermarket pads (Performance friction?), 10" drums in rear also w better shoes and a proper bed in procedure. Wouldn't b as light as the trick stuff but would b adequate if unsprung weight ain't a concern
Re: Ebody Cuda Brakes [Re: RapidRobert] #1044904
08/01/11 09:20 PM
08/01/11 09:20 PM
IN
ahy Offline
ahy  Offline
IN
Agree the 11 3/4 setup up front would be great. A little bigger than the original would have been but looks similar and will fit behind most 15" wheels. You will need late A body spindles. JY's are pretty picked over but MP brakes and others sell a high quality reproduction. See the tech article on Mopar Action's tech pages for more specifics.
