Re: hemi build up?
[Re: FASTFISH420]
#104432
02/14/09 09:33 PM
02/14/09 09:33 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
hello?where are all the hemi guys?
The is the HOT-STREET Hemi I built for the book that will be released in June (How to Build a Max-Performance Hemi". This picture shows EFI but carbs work just as as well. It's also shows coil-on-plug but a distributor would work just fine too.
This is a 572" Hemi: 800 RPM idle at 14" vacuum 700 ft lbs at 3500 RPM (curve was very flat) 725 HP at 6200. On 91 octane but it should be fine with 87 or 89, just haven't tried that yet.
World block, unported Stage-V heads.
With a hydraulic roller would be virtually maintenance free.
Re: hemi build up?
[Re: dthemi]
#104435
02/15/09 12:11 AM
02/15/09 12:11 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
My build is similar to others here. 572" World aluminum block Block honed and prepped @ FHO for CP 10.5 pistons Diamond rings Stage V replacement heads CNC ported @ MCH Stage V rockers T&D shafts, Hi Tech stands K1 crank K1 7.100 rods Comp solid FT Nitrided and using Howard's EDM lifters .620" .630" 258* and 263* @ .050 108 LSA Milodon dual swinging pu pan HV pump MP cross ram with FHO lids or Indy single intake Probably 2 770 SS carbs MP tach drive dist. Chain drive for cam MP water pump assy I am not sure what HP level to expect. ![](/ubbthreads/images/graemlins/shruggy.gif)
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: hemi build up?
[Re: 604 Hemi GTX]
#104438
02/15/09 01:39 PM
02/15/09 01:39 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Hemi Allstate, Just wondering what the stage v cnced heads flowed after they were ported? Planning on building a 604ci hemi for my GTX and not sure which heads to buy.
Contact Tim at FHO. He's doing cnc'd stage v's. He has programs to get the replacement heads flowing 470cfm and his millenium heads flow almost 600cfm. ![](/ubbthreads/images/graemlins/beer.gif)
