Re: Caltracs mono leaf spring problems [Re: Cape] #1043867
08/02/11 02:41 AM
08/02/11 02:41 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
the only thing im worried about is pinion angle and will the u bolts be under any added stress that they will snap. Thanks
If they are the factory bolts that kinda flatten out in the area around the axle tube, with a 4 speed I'd replace them with the ones that keep the same dia all the way around, like those in the pic. As someone mentioned earlier though, you definately need to box in the back half of the perch especially on a 4 speed car or you WILL bend them. My Dad's car had this happen and it is only an 11 sec auto trans car.
Here is how mine were.
Re: Caltracs mono leaf spring problems [Re: StrokerPost] #1043868
08/02/11 05:50 AM
08/02/11 05:50 AM
sweden
sshemi Offline
sshemi  Offline
sweden
dont worry about anything brakeing if all is good i have run my Dart this way all the time running mid 10s with transbrake launches.
Re: Caltracs mono leaf spring problems [Re: sshemi] #1043869
08/02/11 02:41 PM
08/02/11 02:41 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks for all the great info everyone. I just talked to travis at calvert and they want to send me different springs just to keep it in the center.
Re: Caltracs mono leaf spring problems [Re: Cape] #1043870
08/02/11 03:19 PM
08/02/11 03:19 PM
michigan woods
imfixinmopars426 Offline
michigan woods
just installed a set of mono's and bars on a 64 fury. fit was perfect on all accounts. you must have gotten wrong stuff imho.
Re: Caltracs mono leaf spring problems [Re: Cape] #1043871
08/03/11 01:28 AM
08/03/11 01:28 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Good deal.
Again, keep us posted, you will like it, this will all be worthwhile.
Re: Caltracs mono leaf spring problems [Re: theclutcher] #1043872
08/03/11 12:01 PM
08/03/11 12:01 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I have the same exact set-up on a 1969 Roadrunner. I put the spring purch in the front hole and drilled out the front hole on the caltrac lower bar holder/shock mount. I have the super stock spring hangers as well. Everything works great. I have a combo that has 525RWHP/500LBS TQ with a Richmond 5 speed and launch the car at 5500rpm. Wheels up and movin' out!
