Re: subframe connectors
[Re: Challenger 1]
#1041770
07/28/11 01:46 PM
07/28/11 01:46 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
You will find ALL SORTS of flex just doing it that way...
LIFT UP one corner .... and see for yourself...
BS How would you know??
I did my connectors the same way, night and day difference. If I place a jack under the diff on one side it attempts to lift the whole side of the car. I would say they are very helpful.
[Re: 68Bullit]
#1041771
07/28/11 01:48 PM
07/28/11 01:48 PM
Mopar_Country
Under My Car
I know some connectors are pretty detailed with the custom fitting ridges, etc, but I'm just looking for some bolt-on or weld on straight square connectors. Anybody sell these fairly inexpensively?
Also, has anyone made their own????
I made my own for around 36 bucks in material. A little cut here and a weld there, and I'm good to go.
Follow the link Joe provided, that's how I did mine, works well.
[Re: dOc !]
#1041772
07/28/11 02:52 PM
07/28/11 02:52 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
Hay AR ... the "cork" was in-it .... then came the ... ......
No, you are just an irritating aspect of Moparts at this point.
Your input means nothing and your on again-off again CAPS LOCK malfunction is getting OLD.
Let 'er rip...
[Re: PAINT IT BLACK]
#1041774
07/28/11 03:18 PM
07/28/11 03:18 PM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Let 'er rip...
....you don't like it ? ...change-the-channel(don't read it - what-the-hell - if you find it that offensive USE the ignore feature).
That is what most people that have over a room-temperature IQ do.
[Re: MonGoo$e]
#1041775
07/28/11 10:31 PM
07/28/11 10:31 PM
Posts: 571 Western NC
68Bullit
Western NC
much to the chagrin of everyone here i got the MagnumForce double tube style ones. Bolt on each end and to the floors.
I just finished looking at the Magnum Force website and this is what I think I'll go with. Do you notice a difference? And can you tell when you lift one corner of the car up?
[Re: dOc !]
#1041776
07/28/11 11:27 PM
07/28/11 11:27 PM
PAINT IT BLACK
Houston Texas
You haven't been important enough to take the time to ignore... I guess now that you're on my ignore list you've moved up a rung! Congrats.
#1041777
07/29/11 12:28 AM
07/29/11 12:28 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Made my own on my '73 charger, used 1x3 rectangle tube. Welded from where frame horn for rear meets the cross frame (?) on the chassis to where the front frames meet the torsion bar cross member. My crappy former 18 year old selfs welding skills weren't very good but they made an IMMEDIATE difference. They are not straight, or should say parallel, with the rockers because the frame rail come in at different places but I thought it would make more sense to put a direct link between those frame pieces.
Cost me little to nothing and they DONT hang down at all! you have to look up from the pinch point of the rockers to see them.
Make your own, quick, easy, and cheap. You don't have to cut up the floors like everyone tries to convince you. Its not a roll cage.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
#1041778
07/29/11 03:06 AM
07/29/11 03:06 AM
dOc !
Florida STAYcation
Now ME ignore YOU ? ...never happen. It still amazes me how someone WHO SAYS they are going to dental school ...can be so brain-dead.
[Re: johnscudashop]
#1041783
07/30/11 06:28 PM
07/30/11 06:28 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
depending on what class your in for scca rules only allow bolt-in connectors - not welded in. Thats only if your running in autox...and if you care..
