Re: does this sound right? at 55mph tach reads 4000rpms
[Re: kmiller0024]
#1041492
07/27/11 05:32 PM
07/27/11 05:32 PM
Posts: 26,522 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What size 15" tires?
Factory tach or aftermarket?
Have you checked the speedo against a known distance/time?
[Re: rbstroker]
#1041495
07/27/11 06:28 PM
07/27/11 06:28 PM
Posts: 416 Franklin Co. Illinois
runinonmt
"This is going to sound like a smart *** answer, but is the tach switch set to 8 cylinder? Simple thing first." If the tach is set to 6 cyl. 3000 would read 3900 Ron A kid came in the shop with a '69 Roadrunner needing a new coil under warranty. He bragged about being able to shift at ten grand. I told him I could cure that. He said "no way" It was set on 4 cyl.
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: kmiller0024]
#1041498
07/27/11 08:54 PM
07/27/11 08:54 PM
Posts: 60 alaska
kmiller0024
alaska
this is a aftermarket tach, not a factory one and it is set on 8 i checked the speedo and its correct, i even pulled the gears to verify it was 3:55, it was stamped right on the side of the ring gear. and its not stuck in 2nd gear thanks for the replys going to go to some of the requested sites to help figure this out
[Re: kmiller0024]
#1041499
07/27/11 08:58 PM
07/27/11 08:58 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Torque converter not working efficiently? I mean I have 3:55's and I am just about 3000rpm's at 60mph. Hughes street master converter-295/50-15's.
Scott
1969 Super Bee, 383/4 speed
[Re: Mopar_Country]
#1041505
07/28/11 02:34 PM
07/28/11 02:34 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
"does this sound right? at 55mph tach reads 4000rpms"
No, I run 3.55's 26" tire and at 60 I'm right at 2900rpm.
I presume 15" rims...hard to say without tire size...235/60R15 are 26", 255/60 are 26", 275/60 are 28", 295/50 are 26", etc...
IIRC, 3.55's and 27" tall tires, in 3rd (not OD) I'm at 3300 RPMS at 70...
could be possible if you have a ton of converter slip, or you're stuck in 2nd....
[Re: roadrunner7020]
#1041507
07/29/11 06:29 PM
07/29/11 06:29 PM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
I had this problem on my car 3000 stall 255/60/15 3.91.........it was low on fluid.Check that in neutral,sure you knew that.Simplest thing to check.I was tackin 4000 at 60mph.
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
