Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER???
[Re: Todd]
#1041285
07/27/11 04:37 PM
07/27/11 04:37 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Thanks I forgot about adding the ladder bars into the equation I'd assume when just using leafs you'd want some more forward movement, correct? Sorry to hijack Randy I'll buy you a when I see you @ Norwalk
[Re: roadhazard]
#1041286
07/27/11 04:53 PM
07/27/11 04:53 PM
Posts: 1,377 Ohio
Todd
Ohio
When the shocks are on, there is no way for the slider to bottom out in any direction. Works very smooth. Way better than the shackle mess.
[Re: Labratt]
#1041289
07/28/11 10:37 AM
07/28/11 10:37 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
This in mine! I thought they were suppose to be straight up. I also have a hole in front of the one I am using. Would I be better off in the front hole? Uploaded with ImageShack.us
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1041291
07/28/11 10:50 AM
07/28/11 10:50 AM
roadhazard
Akron, Ohio U.S.A.
IMO......YES, YES, YES
[Re: dragram440]
#1041292
07/28/11 11:13 AM
07/28/11 11:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yes it should have the top leaning forward... if you were to lift the body you shackle will run out of travel vs if the top was forward... also if its too far forward it will bottom out on the rear when the spring goes into compression/jounce... so more isnt necessarily better
[Re: Labratt]
#1041295
07/28/11 07:12 PM
07/28/11 07:12 PM
Thumperdart
State of confusion
Exactamundo................. When I was teaching Cab about racing years ago , I kept preaching about finessing EVERY part of the car from bumper to bumper and look at him today! Your car`s bad a$$ to me and runs hard so keep at it.
