ET vs. MPH question... #1041128
07/27/11 02:24 AM
07/27/11 02:24 AM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Does this make sense to anyone? Cuz it sure doesn't to me...
Some background material:
70 Duster
416
12:1
Solid cam (268/276 @ .050)
OLD Victor
Holley 800 (848 cfm)
RHS heads (improved about 10 cfm over as supplied on both sides)
1 3/4 headers
904
Converter with almost perfect slippage %
4.56's
29.5" tall tire
Weight, right at 3100 race ready
The best numbers are as follows (average of cold weather runs)
1.42 60'
6.41 1/8 mile ET
106.8 1/8 mile speed
10.14 1/4 mile ET
128.6 1/4 mile speed
See anything weird there? I do. I feel the car should be at least 130 at the stripe. Although is doesn't leave hard, the 1/8 mile speed tells me it's making decent power from 60' to 660'. Right?
Warmer weather the car has the same timeslip pattern, albeit a bit slower, of course.
Here's a question: With 4.56's at a finish line 7,000 RPM, do I have too much RPM for the small port heads?? I'm wondering if 4.30's would MPH better, WITHOUT giving up ET. It would change the flash of the converter, but I wonder if it would effect the high gear slippage at all??
Would lack of fuel VOLUME cause the low MPH? The fuel system does need updating if I were a betting man, I'd bet it is an issue. Driver says it's still pulling at the stripe, but I wonder it it's beginning to run out of steam for possibly the to reasons above????????????
Or Is my thinking in the wrong direction??
Like to hear some motor-head opinions...
Thanks!
Re: ET vs. MPH question... [Re: cudadoug] #1041129
07/27/11 03:15 AM
07/27/11 03:15 AM
Try jetting the carb. up enough to slow the car down in the 1/4. I had a similar problem with a Holley 850 DP, list # 4781-7, my car ran 10.32 at 129.7 MPH with .110 neeedles and seats in it I had treid jetting it up two jets sizes at the local 1/8 mile track and it didn't respond. I ended up changing the needles and seats to a set of .120 and tha car pick up .2 ET and almost two MPH at the local 1/8 mile track(2500 Ft elevation)I took it back back to the 1/4 mile track at Woodburn this last weekend (180 Ft. above sea level) with the same jetting as before the needles changes and the car slowed down to 10.44 at 126.03 MPH MPH I have a wideban on the car, it had shown that the car was going lean a little at the end of the 1/8 mile and really lean in the 1/4, the changes verified that is was starving for fuel, not enough to make the car nose over or miss, just not enough fuel supply to not respond the the bigger jets I did change the jetting back down two sizes and that helped a little, it was still way to fat with the new needles and seats I will work on that carb. later, I switched the carb(1050 Dominator) and intake (domimator intake flange manifold) this weekend at the track and the car ran 10.03 ET at 133.45 MPH several times, even in worst weather
Re: ET vs. MPH question... [Re: Cab_Burge] #1041130
07/27/11 05:04 AM
07/27/11 05:04 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I put my speed through the wallace calc and it came up with 10.14, mine is in shocks and tyres though. Do you have a dyno sheet for the motor, it's definitely laying down on the top end somewhere, what do you have for a fuel system.
Mine is only 3/8 line, single holley black pump.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: ET vs. MPH question... [Re: cudadoug] #1041131
07/27/11 08:45 AM
07/27/11 08:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its probably your fuel supply... the cam should pull
above the 7000 point so I dont believe its a gear issue...
I have used 1 3/4" headers before and they worked to
higher revs than your pulling... I would look at the
fuel system from back to front and that includes the
needle and seats as Cab said and make sure it flows
the needed amount
Re: ET vs. MPH question... [Re: cudadoug] #1041132
07/27/11 10:02 AM
07/27/11 10:02 AM
gregsdart Offline
gregsdart  Offline
I don't see it as being that far off the mark. Maybe 1 or 2 mph? Could be fuel curve at high rpms, slightly high gear ratio.
Re: ET vs. MPH question... [Re: cudadoug] #1041133
07/27/11 10:25 AM
07/27/11 10:25 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
air into carb optimized at speed?
It wont take more jet, unless it take more air?
what scoop and how high above carb opening.?
jet extensions?
Re: ET vs. MPH question... [Re: theclutcher] #1041134
07/27/11 12:04 PM
07/27/11 12:04 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
what i see is a combo that runs extremely well. the 4 inch crank takes a lot of head.
those heads arent very big on a motor like that, if it was my car i would put a bigger carb on it and probably put less gear in it,never seen a 4 inch motor that pretty much didnt go faster the more carb you put on it. i suspect about 6500-6600 is peak power on that motor, so it just isnt going to pull hard at the big end at 7000 rpm, even my w5 422 motor was " flat" the last 125-150 feet or so from 7000-7400 crossing rpm.
just my
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: ET vs. MPH question... [Re: B3422W5] #1041135
07/27/11 09:32 PM
07/27/11 09:32 PM
cudadoug Offline OP
cudadoug  Offline OP
Thanks a bunch guys! I will sheepishly admit...never thought about the needle and seats. I "thought" I was jetted about right as more jet slows the car down. But the N's and S's are "stock" as for a 4780 carb. The fuel system will get re-plumbed from the regualtor to the carb before next time out, and then I'll be prepared to add bigger needles and seats and THEN start fooling with the jetting again.
Yea, Don I'd like to run the car with a 1000 cfm 4150 carb just for grins as I agree with your theory, but one thing at a time...as time permits.
It's also a little soft on timing at 32 degrees...hmmmmm...
Re: ET vs. MPH question... [Re: cudadoug] #1041136
07/27/11 09:50 PM
07/27/11 09:50 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
thats pretty damn good,i agree those heads aren't the biggest or best..u might just be outta air with that rpm i think thats hallin for that combo
Re: ET vs. MPH question... [Re: fishy340] #1041137
07/27/11 10:01 PM
07/27/11 10:01 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
runs very good
Re: ET vs. MPH question... [Re: cudadoug] #1041138
07/27/11 10:43 PM
07/27/11 10:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Seems to be haulin a$$ to me ESPECIALLY being a small-block..........makes me realize how week my 470 big-block really is.
Re: ET vs. MPH question... [Re: Thumperdart] #1041139
07/28/11 12:03 AM
07/28/11 12:03 AM
cudadoug Offline OP
cudadoug  Offline OP
Enough air?? Never thought of that. It has a 6-bbl scoop, sealed very well to the carb. In fact I tried it without the air pan one outing and the car slowed exactly 1 tenth and just a tick over 1 MPH. We always run the car with an air cleaner also; a 5" tall 10" diameter K&N. Now that you've sparked that idea, I'm going to A) make sure it gets a good cleaning and B) try a run or two without it.
Hey, Dom...apples and oranges...we don't have the go-nads to drive it on the street like you do! If fact, I bet no one here drives a 9 second car on the street as much as you do!!
We're "happy" with the way it runs, especially since it's my first small block build, but being the motor guy, I'm never happy...LOL! I chased the elusive 9.99 time slip all winter and spring, just beating my head against the wall, but plan to go back to that this fall. (Come on late October!!)
Re: ET vs. MPH question... [Re: cudadoug] #1041140
07/28/11 12:48 AM
07/28/11 12:48 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Uh, I believe he meant cfm flow not scoop. The head can only flow so much
Re: ET vs. MPH question... [Re: Mopar-Al] #1041141
07/28/11 01:56 AM
07/28/11 01:56 AM
cudadoug Offline OP
cudadoug  Offline OP
Uh...that would makse sense wouldn't it?? Hadn't my after-work beer yet...
Re: ET vs. MPH question... [Re: cudadoug] #1041142
07/28/11 02:10 AM
07/28/11 02:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looking back, I went a bit quicker/faster w/out my 3 1/2x 14" K&N filter and w/less timing than most run. It may be apples to oranges but some of you small-block guys haul a$$ for sure. I do however drive the hell out my car and I wouldn`t have it any other way. As I`ve said before; I`ll never own any car that I can`t street drive cos it`s just too damn much fun.
Re: ET vs. MPH question... [Re: Mopar-Al] #1041143
07/28/11 10:07 AM
07/28/11 10:07 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yes thats what i meant,,thankyou
Re: ET vs. MPH question... [Re: cudadoug] #1041144
07/28/11 02:22 PM
07/28/11 02:22 PM
I'm sure the .110 needles and seat in my 850 where stock, I used a drill bit to find out what size the hole is in the seats and go from there. My 1050 Dominator was showing similar results on the wideban at Woodburn this past weekend so i will check them now, I should have checked them before using it on the car
Re: ET vs. MPH question... [Re: cudadoug] #1041145
07/28/11 03:59 PM
07/28/11 03:59 PM
Az
Crizila Offline
Crizila  Offline
Az
It could be a fuel problem, but I'm gonna lean towards too much gear, especially with those heads. Making a gear / tire diameter change might improve your speed, but it also might do zero for your ET.
Fastest 300
Re: ET vs. MPH question... [Re: Crizila] #1041146
07/28/11 08:19 PM
07/28/11 08:19 PM
SoCal
Brian Hafliger Offline
SoCal
Max out the pushrod pinch...slow the air down as much as possible and LAAAAAY the short turn back alot. Be carefull but it will go a ways.
Is the cam advanced at all?
Brian Hafliger
