Re: Headers=starters=Big Block=B-Body
[Re: meepmeep70]
#1040646
07/27/11 06:32 PM
07/27/11 06:32 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
What about "shorty" headers? Lots of companies make them (Hedman comes to mind).
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: terzmo]
#1040648
07/27/11 07:06 PM
07/27/11 07:06 PM
Posts: 3,054 USA
b54406barrel
USA
Sure, here you go........
http://www.summitracing.com/parts/HOK-5215-1HKR/
hmm...fenderwell headers for A body...I inquired about B
They're 2" & they work on a 68 road runner way better then they worked on my 67, 440 barracuda. You had to run a mini-tire & jack it way up to clear. They're still on the 68 rr as far as I know. Easy plug changes & you can fit 2 starters up there, side by side. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: terzmo]
#1040649
07/27/11 07:21 PM
07/27/11 07:21 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The question was about 2 inch headers..anyone have them that don't capture the starter...why am I getting questions about the motor build...A body header suggestions and a the rest of somthing I didn't ask for? Either someone has em...or they don't...simple
This is pretty normal around here. But don't let that discourage you !!
[Re: Stanton]
#1040650
07/27/11 09:03 PM
07/27/11 09:03 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
It's like asking My Wife a question.........
[Re: Mr.Yuck]
#1040654
07/28/11 10:23 AM
07/28/11 10:23 AM
terzmo
Pendleton NY
why are you so worried about the starter? it's not a GM.. it will be fine. Not sure of the part # but Hooker makes a race set that are 4 piece, but 2 tubes exit out the inner fenders. Buddy used them on his 69 coronet. If I do 2" that's the way I'm going.
duh...starters fail..
[Re: terzmo]
#1040655
07/28/11 11:01 AM
07/28/11 11:01 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Then run manifolds, really no header is going to give you total easy access to the starter, it's even more of a pain if you have PS. That's why it's good idea to run as many factory ex mani studs as you can. It makes pulling the headers easier. On my last set of hedmans and Summit headers I was able to use all of the ex mani studs. This way you don't have to drain the block before you swap out a gasket or if you have to move the header. FWIW you'll have half a dozen things fail before the starter.
[Re: Junky]
#1040657
07/28/11 01:33 PM
07/28/11 01:33 PM
Mr.Yuck
Brookeville, Md
I run Schumacher Tri-Y headers. Easy install. Doesn't trap starter. Easy access to plugs.
Yes but if he didn't want to use 1 3/4 or 1 7/8 he won't want to use those.
[Re: Junky]
#1040658
07/28/11 01:59 PM
07/28/11 01:59 PM
terzmo
Pendleton NY
neat...what size diameter ? I may have to compromise diameter if the starter is accessable for change
[Re: DaytonaTurbo]
#1040661
07/28/11 03:30 PM
07/28/11 03:30 PM
Mr.Yuck
Brookeville, Md
Really how often are you going through starters that this is that big of an issue for you?
must be a chevy convert...those things eat starters like crazy
[Re: terzmo]
#1040662
07/28/11 03:36 PM
07/28/11 03:36 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
IIRC, 1.58" to 2" to 2.5". Click here for the web page.
[Re: DaytonaTurbo]
#1040663
07/28/11 03:50 PM
07/28/11 03:50 PM
terzmo
Pendleton NY
Why ask this question ? If someone wants a burger, do You question that with somthing else. I hate to be like this BUT if there is nothing POSITIVE to reply with...then don't....I can put all on the ignore list but I'd rather not.
If it's "possible" to make things EASIER down the road, then shouldn't one take that route.
[Re: terzmo]
#1040664
07/28/11 05:29 PM
07/28/11 05:29 PM
DaytonaTurbo
Manitoba, Canada
So basically then you're only looking for the answers you want to hear, not any opposing view points that should at least be considered. You should probably put me and 3/4 of the board members here on your ignore list. ![](/ubbthreads/images/graemlins/eyes.gif)
