Re: Drag Week Duster
[Re: Stroker Scamp]
#1039562
07/26/11 01:21 AM
07/26/11 01:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
totally awesome, remember Road Warrior where he flicks a switch and the blowe kicks in (i know its fake) but??? throw something and the belt engages??
I actually worked on a project like that... we were testing on 4 cyl engines with a belt driven super charger that we used a heavy duty AC clutch to engage the blower... had a micro switch on the the throttle to engage it
[Re: Bigcube]
#1039565
07/26/11 02:32 AM
07/26/11 02:32 AM
Posts: 324 Oklahoma City, Oklahoma
DusterDj
Nice job! Chassis looks great, How tall of tire? I'd like to see that thing 1-2" lower in the back... but I'm sure it will settle when you start adding everything else... Which B1's are they? How many cubes? How much boost?
Tires are 33" in diameter. The reason it is setting high is because the body shop put it back together like that. She will be lower when it is time to run. The B1's are originals but are heavily CNC'ed. Currently we are setting at 572ci, and for the boost level, there is no target boost levels. Once it is on the dyno there will be a kill setting and and drive around setting. So with that being said, how ever much boost she can create is what I'll run once set to kill...
[Re: DusterDj]
#1039570
07/29/11 09:11 AM
07/29/11 09:11 AM
MR_P_BODY
WOW... DJ is the bumper far enough forward to get them in behind it.... damn they stick out there a long way
[Re: MR_P_BODY]
#1039571
07/29/11 09:57 AM
07/29/11 09:57 AM
DusterDj
It has plenty clearance. I thought the same before we trial fitted it, but the provolutes make it a little tight. That won't be a game stopper though...
[Re: RodStRace]
#1039574
07/29/11 03:23 PM
07/29/11 03:23 PM
DusterDj
I realise that's a lot of aluminum but it sure is hanging way out on that stand! Maybe cut a 2X4 to fit under the blower brackets to the base of the stand.....
Thanks for the recommendation but everything has been fabricated to spec to for fill my setup and versatility for the street.
[Re: Thumperdart]
#1039575
07/29/11 03:37 PM
07/29/11 03:37 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
VERY nice............... Sure would be cool to see you up front in the competition. Good luck.
That is a awesome build you've got there!
[Re: DusterDj]
#1039576
07/29/11 03:48 PM
07/29/11 03:48 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I just meant the 4 bolts holding that to the engine stand are under stress, not in the car.
[Re: moparniac]
#1039578
07/29/11 03:59 PM
07/29/11 03:59 PM
DusterDj
think what he is saying is support the front of the engine on the stand!
Oh, I got you but I left Steve Morris in charge of my build. I'm sure he has a handle on it...
[Re: CrAzYMoPaRGuY]
#1039581
07/29/11 07:31 PM
07/29/11 07:31 PM
Posts: 791 Bama
Randy..
Bama
this car pleases me.
I was thinking the very same thing!
I will add....
xs3
