Page 2 of 3 1 2 3
Re: Superbird Overheats [Re: 62maxwgn] #1037014
07/21/11 09:15 PM
07/21/11 09:15 PM
Slidell, LA
Bayou_Bird Offline OP
Slidell, LA
Yes, it has the K member seal.
Re: Superbird Overheats [Re: DAYCLONA] #1037015
07/21/11 09:28 PM
07/21/11 09:28 PM
Slidell, LA
Slidell, LA
The copy paper immediately stuck to the grille. So I take it that the system is getting enough air to cool? Then I don't need the pusher fan?
Re: Superbird Overheats [Re: DAYCLONA] #1037016
07/21/11 09:33 PM
07/21/11 09:33 PM
Slidell, LA
Slidell, LA
I hope the pic attaches. Copy paper sticks to grille.
Re: Superbird Overheats [Re: Viol8r] #1037017
07/21/11 10:23 PM
07/21/11 10:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Can we start with some basic stuff like initial timing and tune before we have this guy rebuild his entire cooling system??!
Just like AndyF said early in this post, get the tune right and it will cool down.
8 times out of 10 overheating problems are tuneup related. imo
Re: Superbird Overheats [Re: Bayou_Bird] #1037018
07/21/11 10:28 PM
07/21/11 10:28 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Steve, based on the air flow test and the 3 degree drop in water temp in your radiator, you are not making enough heat transfer from water to air. I checked my 71 RR last Sunday and had an 18 degree drop (coolant) across the radiator and 160 at the thermostat (housing). My 71 RR has a 22" radiator with 5 blade clutch fan.
Check the air temp entering and leaving the radiator. I would think there should be about 15-20 degrees difference. In 2005 I checked my Challenger (with a 440 and A/C) and had an air temp increase across the radiator of 30 degrees and a lower hose temp of 157. The Challenger had a 26" 4-row radiator.
I bet you are not getting close to that. Bottom line the tubes in the radiator may need to be cleaned to transfer heat properly.
Ron
Re: Superbird Overheats [Re: Bayou_Bird] #1037019
07/21/11 10:29 PM
07/21/11 10:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Well you've confirmed that you have sufficient pull through the grille, I would still replace the fan with a solid/fixed blade,.... your seals are in place, you know the radiator core
has been redone,...but have you confirmed a spring in the lower hose?, just squeeze it to confirm it can't collapse,....again I'll recommend the ZEREX G-05 antifreeze, 50/50 freeze/water mix, with 8-10 Oz of REDLINE WATER WETTER (Autozone)....this antifreeze mix alone was worth an easy 15-20 degrees lower running temp in my Daytona, which always ran 210-230 in slow moving traffic, so I more than know your woes of running hot,.....straight water with water wetter is the most effective cooling mix,....But antifreeze added has the ability to raise the boiling temp of the fluid, combined with water wetter helps to eliminate steam pockets that develope in the cooling system/engine when it reaches operating temps...
What is the initial timing of the engine?
Mike
Re: Superbird Overheats [Re: DAYCLONA] #1037020
07/22/11 02:25 AM
07/22/11 02:25 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Doubt the hose is sucking shut, he says it cools down when driving faster than 45mph on a steady run. I'd bet it's tune related. Only been driven 300 miles in 6 years. You haven't driven it enough to make a difference. Have you flogged it at all? Do you know if it makes any power or runs correctly? Or, do you just drive it around like you're delivering milk? If you can't tune it, take it to someone who knows how. You may well be chasing your tail messing with the cooling system.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Superbird Overheats [Re: phantomx] #1037021
07/22/11 08:41 AM
07/22/11 08:41 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Travis..
Agreed. Go drive the car. For real. The way it was meant to be driven. And not for 10 minutes.
Re: Superbird Overheats [Re: DennisH ] #1037022
07/22/11 09:32 AM
07/22/11 09:32 AM
Slidell, LA
Slidell, LA
When you pay my bills...you can tell me how to drive. I guess jerks are everywhere...even on Moparts. I did not come on here for driving lessons.
Re: Superbird Overheats [Re: Bayou_Bird] #1037023
07/22/11 10:43 AM
07/22/11 10:43 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Steve, I feel your pain.
When I first got my Daytona, it ran so hot it actually caused my wiper squirter hose support loops (the white ones running down the passenger inner fender) to melt. Now, that's hot !! I live down in the South as well. I talked to Ted Janak who lives near me and he had these problems when he had his Daytonas and Superbirds way back in the day. So, it's the nature of these beasts. Is the car purging/overflowing when you turn off the engine after it's heated up? I do know every car's going to be different. When I top off my radiator, the Daytona always purges coolant when I turn off the motor after a trip in the hot weather. But, after a while, it stops once it sort of balances out and it's all good-to-go.
My timing and everything was fine, 10 degree initial if I remember. Maybe even 5. Regardless, the thing that seemed to do the trick for me was the water wetter and distilled water. Of course, I made sure my radiator was in tip-top shape and I was getting sufficient water flow. I changed out the thermostat too if I recall. I tested the one that was in the car in a pot of boiling water and it wasn't opening all the way. So, that was part of my problem. I see you have a solid fan, so that's good (that is your picture of the engine compartment?). Right now, I feel comfortable with going anywhere. I haven't been caught in a bumper-to-bumper traffic jam yet, so I haven't had to test out my new pusher fan.
Don't worry what others may or may not say. Sift through what you need and press on... Believe me, I've gotten plenty of unless replies over the years on threads of mine.
Troy
Houston Mopar Connection Club
Re: Superbird Overheats [Re: hemi68charger] #1037024
07/22/11 11:06 AM
07/22/11 11:06 AM
Unfortunately back in New York
Nukechargerboy Offline
Happy Birthday Nukechargerboy  Offline
Have you made sure the thermostat is good/installed? Sounds to me like there isn't enough time for the radiator to do its job. The water must be moving pretty fast to only get a three degree differential temperature.
Re: Superbird Overheats [Re: Nukechargerboy] #1037025
07/22/11 12:48 PM
07/22/11 12:48 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
I think you need a higher temp thermostat. The 160 is open all the time, allowing maximum flow- but does not keep the coolant in the radiator to sufficiently cool it. The thermostat is designed to open and close to regulate the temp- not just open at a certain temp.
Re: Superbird Overheats [Re: DAYCLONA] #1037026
07/22/11 12:54 PM
07/22/11 12:54 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
DAYCLONA nailed it... get it done right.. good luck dan
Re: Superbird Overheats [Re: Bayou_Bird] #1037027
07/22/11 01:18 PM
07/22/11 01:18 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i dont think they're trying to tell you how to drive. just suggesting thaat, it needs more time driving, and some real "hard running" a bit, to see what it does. if it starts pinging or knocking when you floor it, thats an indication of a possible timing problem.
since it runs cool at speed, it sounds as if the fan isnt moving enough air to cool the water, thats in the radiator. this could be due to restricted tubes in the rad. you can pull the radiator out, and a decent shop can take the tanks off, and build a four or even 5 core radiator, using the stock tanks. it will look stock from above, and from behind. the latch tray will hide the rest, and the extra rows, make a huge difference. if you're sure the timing and carb are right (and you might need to "thrash" it a bit, to find out) then you need to address the rad. one other thing, be sure the radiator cap is the correct one, pounds wise. and have it tested, to be sure it's operating in the correct range. the 160 stat isnt an issue. once it's open, it's open, no matter the range. good luck!!!
Re: Superbird Overheats [Re: Kirby] #1037028
07/22/11 01:22 PM
07/22/11 01:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I agree Kirby, 180 Thermostat probally would be his best selection, that's what I run in my Daytona, and usually recommend that for most wingcars running a stock set-up, to up under 500 HP.....but the OP needs to confirm some items in the cooling system, engine timing, even perhaps carb jetting, and/or air/fuel ratio,.....but one can only assume what/how the OP has/is diagnoising his problems,....we're all armchair quaterbacks because there's little info to go on,..
Mike
Re: Superbird Overheats [Re: Bayou_Bird] #1037029
07/22/11 03:09 PM
07/22/11 03:09 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Not trying to be a jerk. My point is that your car is obviously very nice, but I see lots of beautiful cars sitting on the side of the freeway because they don't run like they look. If you don't want to beat your car on the street, that's ok, find someone to dyno tune it. Having a properly tuned car will pay you back in teh long run.
Travis..
EDIT: I also agree that the 160 tstat is a bad choice. I would do a 180 or maybe even try a 195 to give the coolant more time to transfer heat in the radiator. It may sound counter-intuitive but if you don't regulate that coolant flow it will just keep making the loop getting hotter and hotter.
Re: Superbird Overheats [Re: hemi68charger] #1037030
07/22/11 03:52 PM
07/22/11 03:52 PM
Slidell, LA
Slidell, LA
Thanks so much. I need some encouragement. I do not boil over at all. I have the antifreeze just over the 3 core original MOPAR radiator. I bought a new timing light but the damn thing is defective. I just bought a better one and am going to get my reading on the timing. The good news is....The "mopar doctor" is going to stop by and take a look. I am currenty draining the radiator only and will add water to the mix to dilute it. It seems that most responses have in common, the more water the better. Wish you were here. This overheating problem has been since I have owned the car (2 years). The reason I am trying to correect the overheating is so I can drive it more. My 'Bird is a very important one to the history of Mopar. I will post more about it later.
Re: Superbird Overheats [Re: Bayou_Bird] #1037031
07/22/11 04:17 PM
07/22/11 04:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I hope you were not running just "straight" antifreeze and no water?.....if so start with a 50/50 mix of water/antifreeze,....again I'll recommend the Zerex G-05 brand antifreeze (just 1 gal. the rest water, should be close to 50/50) with 8-10 oz. of Redline Water Wetter added,(Autozone)...you should flush the system completely before using the Zerex....I'd suggest an intial timing of 10 BTDC, when you go to check/reset the timing
Mike
Re: Superbird Overheats [Re: DAYCLONA] #1037032
07/22/11 05:14 PM
07/22/11 05:14 PM
Slidell, LA
Slidell, LA
Hello Mike, I can't believe it but I drained the radiator and added plain hose water. My temperature changed 20 degrees. I am headed in the right direction. I ran it in traffic and the highest temp was 210. So now my mix is what antifreeze was in the engine. I guess I must have 1/2 bottle of water wetter left in the mix. I would like to come down about 20 more degrees to 190. The "Mopar Doctor" is on his way over. Things are looking up. I want to be able to drive this car and enjoy it some. You have restored my faith. MOPAR (my old pig's almost running). HaHa.
Re: Superbird Overheats [Re: Bayou_Bird] #1037033
07/22/11 05:27 PM
07/22/11 05:27 PM
Houston, Tx
Houston, Tx
Awesome................ Now talk to Doug if you haven't already and get up to Indy for the AeroWarrior meet during the Brickyard 400. Fine lookin' Plymouths there......
Troy
Page 2 of 3 1 2 3
