differential gear oil #1036753
07/20/11 07:46 PM
07/20/11 07:46 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
I just dumped the old gear oil from my 93 Dodge diesel dually and replaced it with Valvoline 85W140 High Performance it says it is good for limited slip,,but do I need to still put in an additive for the limited slip carrier??
Re: differential gear oil [Re: dartman366] #1036754
07/20/11 09:02 PM
07/20/11 09:02 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You might have to. I had to add the extra little bottle on a 9 1/4 antispin, and used the same valvoline so I thought it would fly. It didn't..
Re: differential gear oil [Re: buildanother] #1036755
07/20/11 09:09 PM
07/20/11 09:09 PM
IN
ahy Offline
ahy  Offline
IN
I've found "limited slip" lube stills needs the additive.
Re: differential gear oil [Re: buildanother] #1036756
07/20/11 09:10 PM
07/20/11 09:10 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Ok thanks, I have put in 3 quart's so far and still need's some more so I will pick up the additive while I am at the part's store.
