Re: What electric fan to use?? Running hot
[Re: 67GTMIKE]
#1034870
07/18/11 11:45 AM
07/18/11 11:45 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
What size is the core? If it's the same size as a stock 26" fan, there's only one high performance solution. https://board.moparts.org/ubbthreads/show...part=1&vc=1
[Re: 67GTMIKE]
#1034873
07/18/11 03:13 PM
07/18/11 03:13 PM
Posts: 571 Western NC
68Bullit
Western NC
It is moving good air but, I think I need more powerful fans.
You should consider that if it's already "moving good air" that it's probably moving the air good enough, or maybe even more than enough. I'd look elsewhere to solve the problem. OR..... if it is NOT moving enough with an electric fan setup, I'd move away from electric fans and go thermal clutch fan with a shroud after I checked the timing
[Re: 67GTMIKE]
#1034875
07/18/11 05:17 PM
07/18/11 05:17 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
Radiator is 24x16 tanks on top / bottom Fans are 12" 1400 cfm each.
I will look into the benz you have but, I don't think I will have clearence to engine because it is a single fan, motor in middle and like I said I have a 3" think 4 core rad. May be tight fit.
Thanks-
Really!!! Benz fans!? Ok. You have not even checked the basic things yet.
[Re: 67GTMIKE]
#1034876
07/18/11 08:01 PM
07/18/11 08:01 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How "hot" is it running and under what conditions?
[Re: 79powerwagon]
#1034878
07/18/11 10:23 PM
07/18/11 10:23 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
what water pump and houseing are you running??
I am truckless..
[Re: 68Bullit]
#1034879
07/19/11 09:45 AM
07/19/11 09:45 AM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
Agreed. Thermal. Copper. Green coolant. 180 Superstat. Shroud.
[Re: Viol8r]
#1034881
07/19/11 11:28 AM
07/19/11 11:28 AM
Viol8r
Woodinville, WA
I doubt that is your issue. Do you know what your initial timing is?
You are really hung up on the fans and thermostats! I can almost bet you are way off on your timing. That is a lot of motor for someone to make comments like "the timing is not advanced".
I PM'ed you with some questions. I think you will get a lot more information if you start with the basics.
[Re: 67GTMIKE]
#1034882
07/19/11 12:13 PM
07/19/11 12:13 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Ok, here is some more detail:
It is new stroker 72 400 block 30 over to 499 stuffed in an A body 68 Dart. Built for street / strip.
Problem might be aggravated if the engine's not broken in yet?
Hi Flow mech water pump. Using water and the wet water additive that says it helps reduce temp.
There was a batch of aftermarket alum waterpump housings that reportedly had small passages in them. I don't know anything more than that nugget, you'll have to research that one.
Let her run at idel, took around 18 minutes before it climmed to 205 then I shut it down.
205° isn't quite dangerous at idle/no-load, it's just higher than we gearheads want. How much higher would it go? If it's 95° ambient, settling in at say, 208° at idle might be 'normal'.
I took her for a ride and it stayed around 195 till I slow down or stop at a light then she quickly starts to rise and I am forced to shut her down again. I then put in a 160 thermostat and it did not help.
A 160 T-stat will not make an engine run cooler if there is something under-performing in the cooling system. It will simply make it take a little longer to get to that first T-stat opening point and maybe a few after that. Meaning - it buys you a little time, but doesn't change the equilibrium temperature of the system.
[Re: ahy]
#1034886
07/19/11 08:02 PM
07/19/11 08:02 PM
Posts: 7,664 IN
ahy
IN
[Re: 67GTMIKE]
#1034887
07/20/11 02:57 AM
07/20/11 02:57 AM
Andrewh
So I assumed I needed a stronger cfm fan.
what thermostate were you running during the part in yellow?
now that you put a 160 in it, what does it run when you are moving?
it sounds like an air flow issue, if it maintains temp at speed, but not at idle.
not saying there aren't other things to do to help bring temps down, but I don't think a timing change will solve it all either.
[Re: 67GTMIKE]
#1034888
07/20/11 03:21 AM
07/20/11 03:21 AM
Posts: 30,443 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I started out with a 22x16 champinon 4 core rad along with a 16" Zirgo electric fan that stated it pushes 3000 cfm. It would not fit as a puller, so I mounted it in grill as pusher. I did have enough room for a mech fan with no shroud so I ran that as well. No thermostat.
A pusher fan .. mounted on the grille ? ... IMO ....
WHAT will it take to get a puller in there ?
