318 Poly Rocker Arm Disassembly #1034240
07/17/11 02:56 PM
07/17/11 02:56 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
How do you get the rocker shaft off of the head? I have to change an intake rocker. Also where do you get an intake rocker, it's like finding hens teeth. How do you set the lash as well. cold or hot and what .000"????
Thanks,
Jeff
Re: 318 Poly Rocker Arm Disassembly [Re: Cuda340] #1034241
07/17/11 06:05 PM
07/17/11 06:05 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Wow, it's been a while but IIRC, you have to back off all the rocker arm adjusters one at a time so you can pull the pushrods out. Now that you have no pressure on the rocker arm shaft, you pull the locking bolt out and slide the rocker arm shaft out the front of the motor. But this is from memory, it's been 25 years since I worked on a poly anything.
