Page 2 of 3 1 2 3
Re: W7, 8, and 9 Intake Manifolds [Re: Plumb Wired] #1034210
07/19/11 10:29 AM
07/19/11 10:29 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Chapman ported 598
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: W7, 8, and 9 Intake Manifolds [Re: Plumb Wired] #1034211
07/19/11 10:31 AM
07/19/11 10:31 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
420 ported by Matt Hensley, Applied Nitrous Technologies fogger, 4150 to 4500 adapter blended
RIP Monte Smith
aka: OutlawFish
Re: W7, 8, and 9 Intake Manifolds [Re: Plumb Wired] #1034212
07/19/11 10:34 AM
07/19/11 10:34 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
598 w/ Monte Smith fogger
RIP Monte Smith
aka: OutlawFish
Re: W7, 8, and 9 Intake Manifolds [Re: Plumb Wired] #1034213
07/19/11 10:35 AM
07/19/11 10:35 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Kent Ritter 420 repop
RIP Monte Smith
aka: OutlawFish
Re: W7, 8, and 9 Intake Manifolds [Re: MR_P_BODY] #1034214
07/19/11 08:02 PM
07/19/11 08:02 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Heres a pic of one of the first 598s that was rough
cast that I machined to fit a 4500 and doing the port
work... its done now but I still havent run it yet
to make sure of the port balance using EGTs
Man Mike... Did you split another one or is that the same one from a wile back
Re: W7, 8, and 9 Intake Manifolds [Re: emarine01] #1034215
07/19/11 08:16 PM
07/19/11 08:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same one... that was the last of my W manifolds...
that one and my 420 is all I own
Re: W7, 8, and 9 Intake Manifolds [Re: MR_P_BODY] #1034216
07/19/11 08:49 PM
07/19/11 08:49 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Lots of great pics.
Thanks all!
Wonder about all the hrs to finish one.
Saw another Wilson int a while back, just beautiful pcs.
Re: W7, 8, and 9 Intake Manifolds [Re: theclutcher] #1034217
07/19/11 10:02 PM
07/19/11 10:02 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
so which intake works better?
Re: W7, 8, and 9 Intake Manifolds [Re: sixpackgut] #1034218
07/19/11 10:04 PM
07/19/11 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: W7, 8, and 9 Intake Manifolds [Re: MR_P_BODY] #1034219
07/19/11 11:11 PM
07/19/11 11:11 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Seems to be a lot of material left in the intakes pictured.
My 420 does not have much work. I was told by the big NA guys I would be down 50 HP due to how much material is still in my 420. My plenum is quite a bit larger than the ones pictured. The runners are basically as cast with the exception of port matching and blending well up the runners.
It's too hot and I am too lazy to take some pics. Probably should sense they are for sale. But, someone will copy my unskilled work. LOL
The 598 I have was done by a local professional and looks really nice in the plenum but runs abouts the same as the others. At least one would not have to weld over any overcuts.
Leon
Re: W7, 8, and 9 Intake Manifolds [Re: Leon441] #1034220
07/19/11 11:18 PM
07/19/11 11:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My factory 420 doesnt look at all like the Ritter
420 repop
Re: W7, 8, and 9 Intake Manifolds [Re: MR_P_BODY] #1034221
07/20/11 01:21 AM
07/20/11 01:21 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Where are the differences?
Divider length thickness or plenum vol?
On the fence as to using a carb adapter for dominator or carving intake.
With adapter, can at least go back to smaller carb if needed.
Also like idea of splitting the manifold, cant recall who does that.
Re: W7, 8, and 9 Intake Manifolds [Re: theclutcher] #1034222
07/20/11 09:23 AM
07/20/11 09:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just looking down the plenum its different... I think
its the dividers... I'll have to look later today
Re: W7, 8, and 9 Intake Manifolds [Re: MR_P_BODY] #1034223
07/20/11 08:40 PM
07/20/11 08:40 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Great info and pics. So what changed in the 598 to the 598 AB? Rules revision maybe? The AB definetly looks bigger.
Re: W7, 8, and 9 Intake Manifolds [Re: Hot 340] #1034224
07/20/11 09:00 PM
07/20/11 09:00 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
That was the revision.
Re: W7, 8, and 9 Intake Manifolds [Re: S/ST 3040] #1034225
07/20/11 09:29 PM
07/20/11 09:29 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I know the AB was a revision, but exactly what changed? Is there a story there?
Re: W7, 8, and 9 Intake Manifolds [Re: Hot 340] #1034226
07/20/11 09:35 PM
07/20/11 09:35 PM
S/ST 3040 Offline
S/ST 3040  Offline
It was the same "design" just the AB version was cast so
they didn't require so much work to port.
The runners are bigger in the 598AB.
Re: W7, 8, and 9 Intake Manifolds [Re: S/ST 3040] #1034227
07/20/11 09:37 PM
07/20/11 09:37 PM
S/ST 3040 Offline
S/ST 3040  Offline
2
Re: W7, 8, and 9 Intake Manifolds [Re: S/ST 3040] #1034228
07/20/11 09:39 PM
07/20/11 09:39 PM
S/ST 3040 Offline
S/ST 3040  Offline
3
Re: W7, 8, and 9 Intake Manifolds [Re: S/ST 3040] #1034229
07/20/11 09:40 PM
07/20/11 09:40 PM
S/ST 3040 Offline
S/ST 3040  Offline
Last one.
Page 2 of 3 1 2 3
