Help: Six-Pack Fuel Lines
#103313
08/11/08 05:46 PM
08/11/08 05:46 PM
Posts: 157 California
dg_dodge
California
Hi All, I was trying to fix a leaky Accelerator Pump on the center 2-bbl on a '70 440-6 setup. I purchased the new upper steel fuel lines already in anticipation of having problems with the existing fuel lines. But, I am having all sorts of trouble now trying to get the existing lines off the carbs in order to remove them. I first tried loosening the lines for the front and rear at the fuel inlet on the carb. But the inlet adapters in the carb just turned with them. I can't possibly get another wrench in there to hold them still. I next tried removing lines at the brass "T" blocks in the line -- but only one of them will budge. And in the process I twisted the line to the rear carb Question #1 - Can I spray something like PB Blaster or Liquid Wrench on these fittings safely? I would generally never think of spraying stuff like this near the carb, but these things are totally stuck and no amount of force is getting them to move. Finally, I tried putting the lines I had loosened up back in place to at least be able to move the car, but then it started leaking pretty heavily at both the front and rear carbs inlet (where I was trying to loosen early but it only spun on me). I still can't get them to move one way or the other at this point, but I must have done something to get them leaking like this. Does anyone have any suggestions on what I can try next with this? This was my first attempt at carb removal ... a lot of lessons learned here I guess. Thanks a lot for any ideas!
Re: Help: Six-Pack Fuel Lines
[Re: dg_dodge]
#103314
08/11/08 06:13 PM
08/11/08 06:13 PM
Posts: 1,567 Ky
jt4406
Ky
If you are replacing the lines anyway, cut them (large side cutters?) at the fuel line fitting, then use a 6 point deepwell socket to get the line fittng out of the carb fitting. jt
Yeah, it's hopped up to over 160...
[Re: dg_dodge]
#103318
08/11/08 08:45 PM
08/11/08 08:45 PM
Posts: 1,663 E.Amherst, NY
69RR
E.Amherst, NY
I would just let the inlets turn. then when they off you can put a wench on them. I've had to that way. I've had 4 six pack cars and each was bit!h to take off.
Dean
Got my hands on the wheel, foot to the pedal, gonna drive this car till the tires turn to metal - gonna sleep when I'm dead and laugh at the devil..
[Re: 69RR]
#103320
08/11/08 08:56 PM
08/11/08 08:56 PM
dg_dodge
California
I sprayed down the fitting nuts to the fuel blocks with PB Blaster, but I can't get them to budge at all. I don't know how they could have been put on there so tightly, but I just can't move them. Yes, was using a 1/2" flare wrench on this. Also, when I tried to start up the car, I have a pretty good leak going at the carb fuel inlets now. I guess all the turning (of the fitting at the adapter) caused it to spring a leak... uggh... I'm not sure what to do next on this... Can't unscrew the lines at the carb inlet or at the fuel block "T's". Has anyone had to resort to cutting the steel fuel lines to get the carbs off the car? If so, how did you do it? There isn't enough room for a hacksaw.... Thanks guys!
[Re: charger RTSE]
#103324
08/12/08 09:41 AM
08/12/08 09:41 AM
dg_dodge
California
Thanks a lot guys for the answers. I'll need to check out some tools to get these fittings off the carb it looks like.. Though I might have to start with the tubing cutter if nothing else works Now, for the leak (pretty substantial now) that I seemed to have caused by trying to loosen the fittings at the front and rear carb ... Has this happened to any of you guys? I can't tighten (or loosen) the nuts now anymore, though I did put a good twist in the rear's fuel line. I can't get them to stop leaking now. Does this sound like something that the new fuel lines I'm replacing with will help, or might I have damaged the fuel inlet adapters in the carbs by trying to turn the nuts on the lines? If so, I'll start looking around for replacemnts of those as well to be prepared. Thanks much all for your help with this!
[Re: dg_dodge]
#103325
08/12/08 11:08 AM
08/12/08 11:08 AM
buy a set of LINE WRENCHES if you dont already have a set. they are INVALUABLE for removing LINES
#103326
08/12/08 11:17 AM
08/12/08 11:17 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Well, mine turned also and they were new. But I still went ahead and got the Promax line for mine. You can actually take any one of the carbs off and leave the lines attached to work on them. That's cool.
Moparlee
#103327
08/12/08 11:41 AM
08/12/08 11:41 AM
Posts: 441 SF Bay Area, CA
charger440sixpak
SF Bay Area, CA
Any chance you can post a photo so we can see what you're talking about? I think I know what they are...
[Re: charger440sixpak]
#103328
08/12/08 11:52 AM
08/12/08 11:52 AM
think of a 6 point box end wrench with a slot cut thru it for inserting it over the line. The slot is typically a little smaller than one on the HEX sides so you get maximum grip on the fitting
[Re: dg_dodge]
#103330
08/12/08 12:49 PM
08/12/08 12:49 PM
i like those too! what size are they?
#103331
08/12/08 01:23 PM
08/12/08 01:23 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
line wrenches wont make a bit of difference. its the big fitting in the fuel bowl that starts to spin and its hard to hold them in place. use a small tubing cutter and just put the new lines on. the line to the rear carb goes on one way. one end is stightly longer then the other and could make you crazy if you dont notice it. put the lines together hand light till its all back in place then tighten everything down if your acc pump is leaking, i would really consider doing a rebuild on all three carbs while your at it
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: dg_dodge]
#103332
08/12/08 01:28 PM
08/12/08 01:28 PM
Robbins
Joplin, MO USA
Not difficult....but I didn't try using factor stuff. My whole fuel system is custom, so.............
Moparlee
