Safely Hoisting a 440 Block #1030412
07/11/11 08:37 PM
07/11/11 08:37 PM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
Can I safely hoist an assembled 440 block by attaching my lift chains to the most forward and rear (4) manifold bolt holes in a set of 440 EZ heads?
The manifold is an aluminum 6-pack, so I hesitate to use any type of lifting plate across the manifold. Looks like my 4 chain leveler that attaches to my engine hoist will line up nicely with those manifold bolt holes, but I wand to make sure that the aluminum head threads can take the strain of the engine weight.
Mike
Re: Safely Hoisting a 440 Block [Re: mike337] #1030413
07/11/11 09:09 PM
07/11/11 09:09 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
I've done it with a set of edelbrock heads - no problem
Re: Safely Hoisting a 440 Block [Re: bri440] #1030414
07/11/11 10:05 PM
07/11/11 10:05 PM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
Thanx!
I was just imagining threads giving, blocks falling, concrete breaking, car crunching, etc. This car has taken too long to pull together to have it end so tragically because I tried to lift the engine from the wrong area.
Now, if only I could get an answer on the PS gearbox & torque converter bolt question.
Mike
Re: Safely Hoisting a 440 Block [Re: mike337] #1030415
07/11/11 10:08 PM
07/11/11 10:08 PM
AndyF Offline
AndyF  Offline
I make a tool for that application. Part number is AR252 and you can buy it from Mancini Racing. The kit has a pair of brackets in it that bolts to the exhaust side of the cylinder head.
