73 Duster, I have the wire connected at the sending unit for the Fuel, and I have the line grounded similar to how the factory had it.
I have a new engine wire harness for the water temp gauge
My dash wiring is very nice original.
I bought one of those newer upgrade voltage limiters off Ebay to replace the old metal pill style.
Problem is, neither gauge works. I have fresh fuses in the block.
Did the limiter have particular slots for each wire? I believe the one that had the 12v went into a specific slot and thats where I put it...
Not so big on the water temp gauge working since I'm going to go to an aftermarket gauge but I'm really interested in the fuel gauge though.
Anything i am missing or should look for?
