Re: Brake help
[Re: 471b1dart]
#1029103
07/10/11 12:06 AM
07/10/11 12:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a tube chassis dart withe the master cylinder under the floor been having trouble getting the brakes to feel right , 1st push of the pedal goes to the floor , next one pedal is hard , got to checking things out and there is no residual valves in the lines , could this cause the problem? or isit something else? It has 4 wheel disc brakes. Thanks for the help
Yes thats your problem
Re: Brake help
[Re: fishy340]
#1029107
07/11/11 06:23 AM
07/11/11 06:23 AM
Posts: 6,295 U.S.
moparniac
U.S.
I have same issue ! Will a proportioning valve help also? Strange discs all around .
Mopar Performance
Re: Brake help
[Re: moparniac]
#1029108
07/11/11 08:58 AM
07/11/11 08:58 AM
MR_P_BODY
Yes... when the master is lower than the calipers or wheel cylinders the fluid backs up more into the master and the master doesnt have enough volume in the bore to get the needed volume in 1 stroke of the pedal... with the residual valves it holds a small amount of pressure on the fluid so it cant back up
Re: Brake help
[Re: moparniac]
#1029109
07/11/11 02:51 PM
07/11/11 02:51 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
if ur master cylinder is down on the floor low like the brakes are yes u need the prop valve were talkin about,,,if ur brakes go to the floor and then get better...BLEED BLEED AND BLEED EM AGAIN..the air makes the fluid look bubbly white like phlem
Re: Brake help
[Re: moparniac]
#1029111
07/11/11 07:27 PM
07/11/11 07:27 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Here is a trick I learned on bleeding the brakes a few weeks ago. Take your bleeder valves out(the fitting as well as the little bleeder valve)pour brake fluid( I used a antifreeze checker) into the openings and tape the calipers with a rubber mallet. Only a small amount will go in at a time,but let set a hour or two and top off again.Do this several times during the day.When you get to the point you are no longer having to put even a drop in them,let set over night and if all the bleeders are still full bleed your brakes.If not you have to keep putting a drop or two of fluid in till it stays full. This sounds like a lot of trouble,but it was the only way to get the brakes bleed right.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: Brake help
[Re: moparniac]
#1029112
07/11/11 07:50 PM
07/11/11 07:50 PM
MR_P_BODY
Yes that's it! Bled them a BUNCH of times now and doesn't seem to get better! MC is on firewall in stock location also... No prop valve or anything ! Straight hardlined
Since your master is in the stock location and you have tried to bleed them multiple times get a mitivac and put that on a catch bottle(line from the mitivac to the bottle then a line out of the bottle to the bleeder)open 1 bleeder at a time using this at each point... press the pedal a short distance and block the pedal... apply a vac to each bleeder...when you get straight fluid close that bleeder and move to the next... make sure you keep the master full... start at the farthest point from the master... once you do all 4 then do a normal bleed procedure to make sure you have all the air out and the pedal is firm.... you can use silicone to seal the tubes to the lid of the catch bottle to make it vac tight
