440 main bearings #1027863
07/07/11 07:56 PM
07/07/11 07:56 PM
ky
68roadrunner Offline OP
ky
what brand and type do you like 3/4, full groove. do you think it makes a difference.
Re: 440 main bearings [Re: 68roadrunner] #1027864
07/07/11 08:10 PM
07/07/11 08:10 PM
gregsdart Offline
gregsdart  Offline
3/4 grove is plenty of grove to feed the bearing. Even that is considered over kill by some experts, but they make them because of demand. Anything more just takes away bearing area to support the loads, which are heaviest on the cap half of each bearing. No brand preference, I think I have Clevites in there at the moment.
Re: 440 main bearings [Re: 68roadrunner] #1027865
07/07/11 09:37 PM
07/07/11 09:37 PM
Delray beach, Florida
P
Performance Only Offline
P
the demand is there for the full groove bearings simply because they work. getting oil to the rods full time is much more important that losing a little surface area. BB mopar mains have plenty of surface area, even with a full groove to handle horsepower beyond what almost anyone on this site will be making.
machine shop owner and engine builder
Re: 440 main bearings [Re: Performance Only] #1027866
07/08/11 02:52 AM
07/08/11 02:52 AM
Take a look at the standard race full groove Hemi bearings(real wide grooves ) and then look at the race narrow groove wedge bearings or the Federal Mogul truck main bearings with the full, narrow groove Oiling the rods full time is real important if your going to race the motor and shift it above 6000 RPM very often
Re: 440 main bearings [Re: Cab_Burge] #1027867
07/08/11 09:01 AM
07/08/11 09:01 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I,ve run the half groove clevites for over twenty five years,never a failure. I have laid it on the rev limiter set at 7000 plenty of times.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: 440 main bearings [Re: Performance Only] #1027868
07/08/11 09:02 AM
07/08/11 09:02 AM
NC
440Jim Offline
440Jim  Offline
NC
I use the Clevite MS-1277HG which are full groove for the later blocks (large thrust surface blocks). The oil to the rods full time is my reason. My last set of rod bearings were in this motor for over 600 passes, so I am happy.
Re: 440 main bearings [Re: gregsdart] #1027869
07/08/11 09:07 AM
07/08/11 09:07 AM
gregsdart Offline
gregsdart  Offline
Meant to say full grove are considered overkill,,,,,,,,
This is going to be interesting
Re: 440 main bearings [Re: gregsdart] #1027870
07/08/11 09:34 AM
07/08/11 09:34 AM
ky
ky
from what i find only federal mogal and clevite make a h series for this engine, is this correct?
