A833-od with no reverse switch??
#1027638
07/07/11 01:15 PM
07/07/11 01:15 PM
Posts: 752 AZ - The "dry heat" state
71autoxr
I have a 1976 vintage aluminum case 833-od. The case is tapped for a reverse switch, but in it's place was a steel plug with a spring and ball bearing. The plug looks to be a factory deal, and not a cobble to fill the void from where the switch is supposed to be. I'm not too familiar with 4 speeds, but what would be the reasoning for the trans "not" to have a reverse switch? Am I right in "ass'uming that I can remove the plug, and replace it with a reverse switch for my application?
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
Re: A833-od with no reverse switch??
[Re: 71autoxr]
#1027639
07/07/11 02:34 PM
07/07/11 02:34 PM
Posts: 26,011 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The plug/spring/ball isn't the BU light switch opening, it's the Reverse lever detent ball housing.
The BU light switch opening is above that.
[Re: John_Kunkel]
#1027640
07/07/11 05:31 PM
07/07/11 05:31 PM
71autoxr
Thanks John. The smaller opening above the reverse lever detent ball housing also has a plug. I cant think of why there would be a plug and not a switch there.
[Re: 446acuda]
#1027642
07/07/11 07:14 PM
07/07/11 07:14 PM
John_Kunkel
Rio Linda, CA
The plug (P/N 1139153) was used from '49 to '75 but I, too, find it strange for it to be in years after BU lights became standard in cars...maybe not in trucks. The partial VIN stamped in the case might show a truck origin.
[Re: John_Kunkel]
#1027643
07/07/11 07:49 PM
07/07/11 07:49 PM
71autoxr
Thanks for the info John. I guess I was just more curious than anything else. Ironically the trans does have the clip to hold the bake up lamp wiring to the case. Now, any good tips to get the detent ball and plug back in the case? Guess I'm gonna have to open it up.
[Re: 71autoxr]
#1027644
07/08/11 09:39 AM
07/08/11 09:39 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
You took it out ? Did you get it all out or did the ball fall back inside ?
Anyway it's easy to reassemble , put the holder , part with big nut , in first , drop in the ball in , then the spring , then the cap . use new gaskets ., the gasket for the cap is the same as the switch.
