Roll bar covers/protectors #1027595
07/07/11 10:38 AM
07/07/11 10:38 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
What are you guys using to protect the bars from scuffs/scratches at the points where you get in/out?
I have seen some "carbon fiber" covers. Any brand you suggest?
http://www.dragonplate.com/ecart/categories.asp?cID=78
Re: Roll bar covers/protectors [Re: TheOtherDodge] #1027596
07/07/11 11:15 AM
07/07/11 11:15 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Seems to me the 3M "clear bra", aka "helicopter tape", would work well for that.
Re: Roll bar covers/protectors [Re: topside] #1027597
07/07/11 11:23 AM
07/07/11 11:23 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use the carbon covers from RJ racecars. You can get them from all the major chassis shops as well.
Re: Roll bar covers/protectors [Re: Al_Alguire] #1027598
07/07/11 01:01 PM
07/07/11 01:01 PM
Out West
408strokerdart Offline
Out West
Ditto. They are just thin carbon tubes that have been split in half. You can probable buy the tube and split it yourself cheaper. They fit good though.
Re: Roll bar covers/protectors [Re: 408strokerdart] #1027599
07/07/11 08:02 PM
07/07/11 08:02 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
James
made these myself out of 6130 aluminum tubing
Re: Roll bar covers/protectors [Re: MOPARCHAS] #1027600
07/07/11 08:03 PM
07/07/11 08:03 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
another one
Re: Roll bar covers/protectors [Re: MOPARCHAS] #1027601
07/07/11 09:31 PM
07/07/11 09:31 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Must be a street car, race cars must have that area padded.
Re: Roll bar covers/protectors [Re: rowin4] #1027602
07/07/11 09:44 PM
07/07/11 09:44 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
was going to say mines got padding
Re: Roll bar covers/protectors [Re: sturmenater] #1027603
07/07/11 10:43 PM
07/07/11 10:43 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
wrong on both counts
the only area that has to be padded in a cage is the area around you head per NHRA rules
my chasis is certified to 8.50
Re: Roll bar covers/protectors [Re: MOPARCHAS] #1027604
07/07/11 10:52 PM
07/07/11 10:52 PM
rowin4 Offline
rowin4  Offline
I always thought it said padding was required anywhere your body could hit which included that area. If that is true I could have saved a couple of bucks on padding.
Re: Roll bar covers/protectors [Re: rowin4] #1027605
07/07/11 11:00 PM
07/07/11 11:00 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
Steve
no reason not to have padding where ever you want but next time you are watching racing on the tv look at pro stock, funny car, top fuel are any class you see all kinds of padding in the helmet area but no where else
Re: Roll bar covers/protectors [Re: MOPARCHAS] #1027606
07/08/11 09:45 AM
07/08/11 09:45 AM
Houston, Texas
Houston, Texas
Thanks for the ideas guys! And he is correct, only padding by head area is required.
