Stroker Hemis, What do you have? #1027446
07/06/11 11:33 PM
07/06/11 11:33 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
I'm bored tonite waiting on parts for my 528. Don't know what kind of response I'll get but I'll ask anyway.
What size, what engine package, HP, 1/4 mile performance, what chassis? Can't remember if there has been a post devoted only to this, Wedges need not apply. Dave
Re: Stroker Hemis, What do you have? [Re: quickd100] #1027447
07/07/11 12:05 AM
07/07/11 12:05 AM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
545ish,4'5 stroke and 4.391 goew,Tt been wirkin so far
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stroker Hemis, What do you have? [Re: hemi-itis] #1027448
07/07/11 12:08 AM
07/07/11 12:08 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
484 cubes with a 4.15" crank and 4.310" pistons at 11.6:1 on pump. Should be good for 9.80-9.90 in my '70 Cuda that weighs 3240lbs in pro street trim...In the middle of putting it back togather, I kept having oiling issues to the push rods.
I also drive a '70 Charger with a mild hemi that is at the same cubes (484) after the last rebuild and a solid .560 cam, 10.5:1 and a Ray Barton intake with a 950 carb on pump gas, and weighing in at 4010lbs with driver, I have netted an 11.13 on drag radials...Nearly stock config and is driven almost daily.
Re: Stroker Hemis, What do you have? [Re: hemi-itis] #1027449
07/07/11 12:14 AM
07/07/11 12:14 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
the stroke in mine is only 4.225 wich i think comes out to like 488 cubes
id love to be able to say it 500+ cubes
dont have any rods/pistons yet so maybe i can find a nice 4.500 stroke crank when go to nats lol
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Stroker Hemis, What do you have? [Re: quickd100] #1027450
07/07/11 01:24 AM
07/07/11 01:24 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Sold my 472 before I finished the car. New mill is 572" 4.5" X 4.5" World alum block, Stage V heads & rockers, CNC work by MCH, 10.5 CP pistons, K1 crank & 7.100" rods. Custom Solid Roller from Dwayne Porter, choice of two intakes , Indy single, or Old Rat Roaster X Ram, with 770 Holleys. Chassis is a Art Morrison with 71- 72 Pinto Spindles, ladder bars and Dana 60 rear with 4.10 gears. 727 trans with PTC converter. The body has glass front end, doors, and quarters.
I haven't run the engine yet probably wait til fall. Too hot now. The car is apart for painting.
How fast? Good question!
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Stroker Hemis, What do you have? [Re: Hemi Allstate] #1027451
07/07/11 03:09 AM
07/07/11 03:09 AM
Netherlands
72Challenger Offline
Netherlands
528ci Hemi, 4.50 bore x 4.15 stroke in a KB alloy block. Steel rods with forged pistons, pumpgas comp ratio topped with '66 alloy heads ported w/ stock rockers. Barton single intake w/ 1050 dominator. Solid flat tappet cam .667 lift 283 dur@050. Backed up by a GForce 4speed with Advanced Clutches package, Dana60 4.56 gearing.
Dropped in a frame rails / chassis 8.5cert. Challenger RT running a best of 9.21@149mph on it's 2nd full 1/4m run.
Re: Stroker Hemis, What do you have? [Re: 72Challenger] #1027452
07/07/11 03:22 AM
07/07/11 03:22 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
572, World block, StageV heads and intake, Crane roller cam, 9.5-1 MP pistons, stock rockers with Dvorak stands and Dechelles shafts, K1 rotating assy, 6.86-1.031 rods. Needs assembly when it cools down. Tim
Re: Stroker Hemis, What do you have? [Re: astjp2] #1027453
07/07/11 07:15 AM
07/07/11 07:15 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
494,500,526,528,540,572,588,605,632,
Re: Stroker Hemis, What do you have? [Re: B G Racing] #1027454
07/07/11 07:45 AM
07/07/11 07:45 AM
nielsville, minn.
Q
Q
nielsville, minn.
OK Bob, UNCLE!, you win . Dave
Re: Stroker Hemis, What do you have? [Re: B G Racing] #1027455
07/07/11 08:51 AM
07/07/11 08:51 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: Stroker Hemis, What do you have? [Re: HEMIFRED] #1027456
07/07/11 10:11 AM
07/07/11 10:11 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
BAE 499.
Re: Stroker Hemis, What do you have? [Re: BobR] #1027457
07/07/11 11:25 AM
07/07/11 11:25 AM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
511 ci, tfx block, aj stage 2 heads, f3r procharger.
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: Stroker Hemis, What do you have? [Re: quickd100] #1027458
07/07/11 11:30 AM
07/07/11 11:30 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
557" pump gas by DTHemi and lays 600 to the tires
Soon to be in Mopar Muscle
Re: Stroker Hemis, What do you have? [Re: RV2] #1027459
07/07/11 11:37 AM
07/07/11 11:37 AM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
My personal pump gas 572 is low buck(relatively speaking) with wiseco/MP pistons, manley rods, k-1 crank, 1st gen MP aluminum heads that I ported, stage V intake with two 800 cfm edelbrocks. It's in a 70RR and is 4044# race weight with driver. It went 9.98 at 139mph last friday in the heat with M/T drag radials.
Re: Stroker Hemis, What do you have? [Re: CRE2004] #1027460
07/07/11 01:45 PM
07/07/11 01:45 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
68 Dart GTS H-code
combo as of now, might be time for some changes this winter....
505 CI HEMI machined and built by me
mega block, 4.400 bore 4.150 stroke eagle crank
diamond custom pistons, 10.7:1 1/16 1/16 3/16 moly rings
manly H-beams 6.865 Bob Weight 2627
Schneider Solid Roller custom ground 260/266 .620/.600 @ 112
BMS roller rockers 1.53 intake / 1.57 exhaust
Smith Brothers pushrods
MP Iron Heads, mild hand port and bowl work
MP cross ram, port matched. 2 Holley 770 cross ram carbs
Charlies 10 Quart oil pan w/ milodon single line external swinging pickup
MSD 6AL W/blaster coil
AC R44-XLS plugs (cheap and easily available)
Holley HP150 pump no return/ using stock gas tank
727 built by my Father
alum front drum
A&A valve body
9" J-Converter
Dana 60
Detroit locker
4.56 gears W Strange 35 spline axels
Caltrac's with mono leafs
Rancho adjustable shocks on rear
Calvert 90/10's up front with RMS tubular uppers and strut rods
Car weighs 3780 with a Half tank of gas and my ass in the seat
leaving from idle off foot brake
60'......1.446
330.....4.255
1/8.....6.605
MPH...104.54
1000...8.636
1/4.....10.359
MPH...130.38
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Stroker Hemis, What do you have? [Re: 68 HEMI GTS] #1027461
07/07/11 02:02 PM
07/07/11 02:02 PM
pa
572charger Offline
572charger  Offline
pa
606 pump gas 11.7 to one solid roller stage V hemi standard port heads barton t-d rocker gear [best hemi investment] 7000+ miles worn out 22% leak down runs 9.60s at 141+ and its 3910lbs et streets , been 8.90s on pumpgas and no2 !!! id rather drive it than race it !
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Stroker Hemis, What do you have? [Re: 572charger] #1027462
07/07/11 03:32 PM
07/07/11 03:32 PM
California
mickm Offline
mickm  Offline
California
540 incher in the works:
mopar siamese block
4.5 bore X 4.25 stroke
7.1 inch rods from FHO
CP pistons 10.25:1
stage V heads ported prepped by FHO
OEM style rocker also from FHO
stage V dual inline intake
650 eddy carbs
haven't decided on a cam yet. either (not exact numbers)
hydraulic flat tappet - 240 @ .50 .560 113 lsa
or similar but slightly more aggressive solid flat tappet
or roller, don't know specs yet
i can only get ~10" of tire under the rear without mods that i'm not up for now, and the 472 in there now tears them up, so even with the hydraulic flat tappet i'm still going to have more power than i can hook with.
but on the other hand, can you ever have too much power?
so i may still go roller...
Re: Stroker Hemis, What do you have? [Re: mickm] #1027463
07/07/11 03:43 PM
07/07/11 03:43 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
572 with a bunch of secret stuff by mch . so far 3400 10.5w 896@151.51.
Re: Stroker Hemis, What do you have? [Re: ro23car] #1027464
07/07/11 04:35 PM
07/07/11 04:35 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
477 Hemi. 4.28" bore, 4.15" stroke. Original iron heads with a little work by Dvorak. Barton single 4 intake modified for EFI. Small Crower street roller. K1 billet rods and ICON 10:1 pistons. NOS Big Shot kit as well. Backed by an ATI T400 trans with gear vendors overdrive. Engine is in a 71 pro street Demon. No times yet. Hopefully later this year though.
Re: Stroker Hemis, What do you have? [Re: ro23car] #1027465
07/07/11 04:39 PM
07/07/11 04:39 PM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
540 4.375 bore X 4.5 crank. Not built yet. It will be going in stock trim 69 charger with hemi 4 speed and 4.10 Dana.
Cast iron block
Indy aluminum heads (426-1 Legend heads)
Indy roller rockers
Custom solid roller cam
Crane solid roller lifters
Eagle 7.1 rods
Eagle 4.5 crank
Custom Diamond Pistons (11 to 1)
Should be fun!!
