Re: I've had it. My car is killing me (904) drama
[Re: FIREGUY12]
#1025422
07/04/11 08:36 PM
07/04/11 08:36 PM
Posts: 30,547 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
We replaced everythng in the trans. the only thing left was the case. And if you do a little internet research you will find some chrysler transmission years ago had problems with the cases. Internal leaks.
Where was the leak ? ... crack, porus ...???
[Re: 408strokerdart]
#1025423
07/04/11 10:20 PM
07/04/11 10:20 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
well here in Ohio we have 15 tracks.. really not sure of how many? but I got 5 with in 1.5 hr. You can race Fri-sat-sun. most tracks around here do 3 times runs and takes 7-8 rd to win. but we do all the mopars races and they are 3 day races with 2-3 times runs and 7-8 rds to win a day..you can rack up some runs real quick..and we have wed-Thu test and tune at most tracks also. entry fees 40-60 bucks .plus fuel per race..so 300 bucks you can put 25-30 runs a weekend on your car
He is also entering multiple classes per day. Three classes on Saturday Mopar events (10.0, Pro & Super Pro), two classes on Sunday (Pro & Super Pro) = alot of passes with elevated trans temps.
To answer your question Lonnie, I have my old 727 race converter here that you are welcome to use. Been trying to sell it for months with no success, it is fresh and was working perfectly. Might be a little more stall than you need though. Was going 5900 behind mine. Let me know, would like to sell it but not going to give it away to anyone else.
Hey Bro, what is the input on that converter? It is a turbo 400 input right?
[Re: wheelsup68dart]
#1025425
07/04/11 11:24 PM
07/04/11 11:24 PM
Posts: 3,456 Out West
408strokerdart
Out West
Stock 727.
#1025427
07/04/11 11:33 PM
07/04/11 11:33 PM
Posts: 20,720 in a cattle trailer down by th...
Guitar Jones
You can buy cases here, they are really reasonable. https://www.wittrans.com/default.aspx
[Re: fishy340]
#1025429
07/05/11 12:29 AM
07/05/11 12:29 AM
408strokerdart
Out West
Brian i have his sollution in my garage
I have his solution in my shop also, but that solution is going back in my car this week.
[Re: eds dart]
#1025433
07/05/11 05:34 PM
07/05/11 05:34 PM
408strokerdart
Out West
Hey Lonnie Ed here, pitted next to you at Muncie this weekend. I,ll second the case leak deal. Buddy of mine is tranny guy at local shop, did a 84 4wd Blazer 3 times. it was smoked when it was towed in 3 rebuilds new valve body, wat cured it was a new case. couldn,t see anything wrong with it dont know if it went porous or was cracked but it does happen and is cheap enough to try. sounds like you got good parts in it that should survive.
I second this as your best low buck way to get thru the rest of the season....then go to the glide.
[Re: CRT]
#1025436
07/05/11 07:19 PM
07/05/11 07:19 PM
Guitar Jones
I'll second the motion to replace the case. Many years ago, I had a customer's race car trans suddenly refuse to shift into high gear at the track. After 3 failed rebuilds and replaceing everything but the case, the only other option was the case. Transfered all of the internals into a different case and the problem was gone! The offending case was examined and couldn't see anything wrong with a visual inspection. Results speak for themselves.
Was it a 904 you where working on ?
John, what is the exact mismatch here, different year parts or what?
[Re: CRT]
#1025439
07/05/11 08:48 PM
07/05/11 08:48 PM
Guitar Jones
OK I get it, I just looked at the only stripped spare case I have and it looks like the one pictured. Thanks for that, I never had occasion to run into that before.
