Re: transmission speedometer housing [Re: cornet684me] #1024570
07/06/11 12:37 PM
07/06/11 12:37 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Look in the trans classified section here on Moparts for the gear.
Someone posted both o-rings sizes a few years ago, but I don't know if that info was ever added to the tech archive.
Basically, head to your local Ace or True Value Hardware store with the gear and housing in hand, and size up the two o-rings.
Stanley, care to elaborate? Have you got a sub-29 tooth gear?
Re: transmission speedometer housing [Re: cornet684me] #1024571
07/06/11 01:32 PM
07/06/11 01:32 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
i have changed from 2.76 to 3.55 gears and the speedometer is way off, i also have 150 lens on a 120 speedometer, i am wondering if i will ever get close enough with this to be able to trust my speedometer
basically ... NO ...
Re: transmission speedometer housing [Re: In_The_Pink] #1024572
07/06/11 01:36 PM
07/06/11 01:36 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I might have one , assuming I didn't throw it out , what tooth ?
Re: transmission speedometer housing [Re: In_The_Pink] #1024573
07/06/11 02:23 PM
07/06/11 02:23 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
What's a "sub"-29 tooth gear as oppose to any speedometer gear?
I'm using a 31 tooth (black) gear for my 3.55 rear and 30" diameter tire.
Or are you referring to a gear with less than 29 teeth and uses a different adapter?
What my was about is that this thread reminded me if I've got it indexed properly...
Gotta get under there when I'm motivated enough.
Re: transmission speedometer housing [Re: cornet684me] #1024574
07/06/11 03:09 PM
07/06/11 03:09 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
The seals for the speedo adapter should be available from the dealer or TF Patty on e-bay.
You need the gear ratio and tire diameter to compute the correct pinion gear.
Re: transmission speedometer housing [Re: John_Kunkel] #1024575
07/06/11 03:16 PM
07/06/11 03:16 PM
Under My Car
Mopar_Country Offline
Under My Car
Here's a breakdown.
Re: transmission speedometer housing [Re: Commando1] #1024576
07/06/11 04:04 PM
07/06/11 04:04 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
That's what I was wondering. I couldn't remember the specific number of teeth which requires the special housing.
Re: transmission speedometer housing [Re: In_The_Pink] #1024577
07/06/11 08:57 PM
07/06/11 08:57 PM
Commando1 Offline
Commando1  Offline
Actually, the way Iremember it was that the diferance was at the 25 tooth count.
Re: transmission speedometer housing [Re: Commando1] #1024578
07/06/11 09:18 PM
07/06/11 09:18 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
special housing is for 21 to 25 tooth gears.
Re: transmission speedometer housing [Re: Mopar_Country] #1024579
07/06/11 10:49 PM
07/06/11 10:49 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
thanks for the diagram , a picture saves alot of time and questions
Re: transmission speedometer housing [Re: JohnRR] #1024580
07/06/11 10:51 PM
07/06/11 10:51 PM
Brandon, Ms
Brandon, Ms
john, how close do you think i can get with some experimenting?
Re: transmission speedometer housing [Re: John_Kunkel] #1024581
07/06/11 11:21 PM
07/06/11 11:21 PM
Brandon, Ms
Brandon, Ms
how can i find TF Patty on ebay?
Re: transmission speedometer housing [Re: cornet684me] #1024582
07/06/11 11:26 PM
07/06/11 11:26 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
No clue , let us know how it works out for you .
Re: transmission speedometer housing [Re: JohnRR] #1024583
07/06/11 11:32 PM
07/06/11 11:32 PM
Brandon, Ms
Brandon, Ms
Re: transmission speedometer housing [Re: cornet684me] #1024584
07/07/11 10:09 AM
07/07/11 10:09 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
ebay search 'torqueflight speedo'
Re: transmission speedometer housing [Re: cornet684me] #1024585
07/07/11 01:41 PM
07/07/11 01:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why experiment? Just supply the gear ratio and tire diameter and get the correct part.
Here's a link to TF Patty's offering, always available but not reasonably priced IMHO. I'd check with the dealer first.
http://cgi.ebay.com/ebaymotors/Mopar-SPE...sQ5fAccessories
Re: transmission speedometer housing [Re: John_Kunkel] #1024586
07/07/11 03:38 PM
07/07/11 03:38 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Because he mickey moused a speedo repair , he put a 150 gauge face on a 120 speedo cluster , putting the correct gear will make it read properly to the cluster but not the gauge face .
Re: transmission speedometer housing [Re: JohnRR] #1024587
07/07/11 06:24 PM
07/07/11 06:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I know, but there is an 80% factor between the 120 and 150 speedo and that can be figured into the pinion calculation. Of course, the odometer will become useless.
Re: transmission speedometer housing [Re: John_Kunkel] #1024588
07/07/11 10:25 PM
07/07/11 10:25 PM
Brandon, Ms
Brandon, Ms
i hope i can get it close enough to use, i will try the web site,
i will post my findings once i figure it out
Re: transmission speedometer housing [Re: cornet684me] #1024589
07/08/11 02:13 PM
07/08/11 02:13 PM
Knoxville, TN, USA
mantonas Offline
mantonas  Offline
Knoxville, TN, USA
I bought a pinion gear about 4 years ago from the local Chrysler dealer (which has since stopped being a Chrysler dealer due to the auto bailout; now they sell Kias). I figured out which one I needed and what the current part number was using the resources here on Moparts.
69 Chrysler 300 Convertible 77 Chrysler New Yorker Brougham 2-dr 03 Jeep Grand Cherokee Limited
