70 cuda headlight stainless trim #1022639
06/29/11 10:46 AM
06/29/11 10:46 AM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
Are both sides interchangeable? I only have one side and need to know if there is a right and left or if this piece fits both sides...thanks Moparts!
http://imageshack.us/photo/my-images/98/img2902v.jpg/
Re: 70 cuda headlight stainless trim [Re: redwrydr] #1022640
06/29/11 04:43 PM
06/29/11 04:43 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
There is a left and a right. They are close, but different.
Re: 70 cuda headlight stainless trim [Re: redwrydr] #1022641
06/29/11 06:43 PM
06/29/11 06:43 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
If you are talking about the stainless ring that holds the headlight in - there is no left or right.....Both sides are identical. OOOPS! Just looked at your photobucket pic...You were talking about the bezels.
Re: 70 cuda headlight stainless trim [Re: 6pkaar] #1022642
06/29/11 11:35 PM
06/29/11 11:35 PM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
OK....I really didn't want to have to take the one I have on the plane to Carlisle but I probably will because I have no idea how to tell which side is which...it was not on the car when I got it, it was loose, so I will pack it up! Thanks!
Re: 70 cuda headlight stainless trim [Re: redwrydr] #1022643
06/30/11 02:21 AM
06/30/11 02:21 AM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
Ah but wait....I found out that I have the drivers side so I will NOT need to pack it with me...just need to look for a passenger side at the swap....all is well! Thanks!
Re: 70 cuda headlight stainless trim [Re: redwrydr] #1022644
07/02/11 05:38 PM
07/02/11 05:38 PM
California
1970mopar Offline
1970mopar  Offline
California
They should be stamped "L" and "R" if I recall
Re: 70 cuda headlight stainless trim [Re: 1970mopar] #1022645
07/02/11 06:35 PM
07/02/11 06:35 PM
Northern California
redwrydr Offline OP
redwrydr  Offline OP
Northern California
Hi Pete,
That would sure be handy ...I turned mine every which way to see if I could see an "L" stamped into it somewhere,could you head me in the right location to look? Thanks!
Re: 70 cuda headlight stainless trim [Re: redwrydr] #1022646
07/03/11 06:56 PM
07/03/11 06:56 PM
California
1970mopar Offline
1970mopar  Offline
California
see photo of the LEFT side stamped "L" on the outer edge. Sorry I don't have a photo handy of the corresponding side stamped "R".
Re: 70 cuda headlight stainless trim [Re: 1970mopar] #1022647
07/04/11 11:53 AM
07/04/11 11:53 AM
o
wunderless Offline
wunderless  Offline
o
Left as in drivers side I assume?
But existing is basically all I do.
