Re: Hughes/Edelbrock FI Magnum Intake - real experiences??
[Re: goldmember]
#1022197
06/29/11 07:03 AM
06/29/11 07:03 AM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
The tune is a bigger factor than the intake. The factory tune is a mile off.
That would be my advice, get a tuner for it.
[Re: gdonovan]
#1022198
06/29/11 08:00 AM
06/29/11 08:00 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
look into an SCT tuner. the guy can write a tune specific to the mods in your engine, and if you have a data logger, he can then customize the tune to exactly what your engine needs.
plus he can raise shift points, but if you don't change the intake, exhaust, then a higher shift point does you nothing, since you can see how choked off the stock stuff gets above 4500 rpm. there's a reason the stock stuff had a factory redline of 5200 rpm.
a cam, intake, headers, computer tune will get you around 100 hp gain. but, you're looking at $1,200-$1,300 to do all that. (SCT--$300, Intake--$300-ish, headers $200, cam/springs/retainers--$500
While you probably won't gain any MPGs, you can increase performance a TON, and keep the MPGs the same.
with my 5.2L 3.92 gear Dakota, stock MPG was around 16-18 overall. I have intake, cam, headers, SCT tune, the truck feels like it's around a 300 hp set-up, sounds great, is fun to drive, and still get 17 mpg on the highway
**Photobucket sucks**
[Re: 70Cuda383]
#1022199
06/29/11 08:28 AM
06/29/11 08:28 AM
Posts: 859 VA
AtomicDog
VA
Thanks for all of the responses. I'm relatively happy with the truck's overall performance right now - just trying to optimize gas mileage. I just put a used 5.9 Magnum motor out of a '99 Dakota into my '96 Ram 2500 4x4 truck and did several stock/enhancement mods to the engine prior to the install (roller chain/gears/tensioner, HV oil pump, MP oil pump drive, Milodon 8qt oil pan, valve job on heads and new head gaskets, Hughes aluminum kegger intake lower plenum kit, shorty Pacesetter headers, new distributor/water pump, cleaned/bead blasted throttle body, new distributor, plugs, plug wires, etc.). After getting engine installed, motor runs like a clock - just really want to optimize mileage at this time - also plan to swap the R46RH tranny with a rebuild unit with Transgo shift kit, new converter and deep trans pan soon. Just want the truck to be reliable and pass a gas station from time-to-time.
[Re: AtomicDog]
#1022200
06/29/11 09:52 AM
06/29/11 09:52 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
If the Hughes Magnum Intake were to truly improve MPG, what would be doing it? I can't think of any effect at part throttle, except if the different runner design provided a more equal cylinder-to-cylinder air to fuel ratio. There is some evidence that the stock kegger intake may allow cylinders 7 and 8 to run a bit leaner ... what I mean is that those two back runners flow a bit more than the other six, which with the same fuel injector flow mean the back two have a air to fuel ratio above 14.7 The spark plug ceramics on cylinders 7 and 8 almost always seem whiter after 20,000 to 30,000 miles of use. The majority of blown head gaskets reported by owners are on cylinders 7 and 8. If you wait until a very hot and dry summer afternoon, then fill up with 85 or 87 octane and do full throttle runs up a steep hill, a 5.9 Magnum V8 with the stock kegger intake manifold will many times begin pinging slightly at 3500 to 3800 rpm (unless it has been 'Death Flashed') This pinging can be made to go away temporarily if you either: 1. De-carbonize cylinders 7 and 8 with Mopar Combustion Chamber Conditioner spray. or 2. install 'fires in oil' spark plug extension sleeves on cylinders 7 and 8 or 3. Swap cylinders 7 and 8 to Autolite 3923 spark plugs with their short nose design. Instead of changing to the Hughes intake manifold, it might be possible either to install slightly larger fuel injectors in cylinders 7 and 8 (bigger than 23.2 lbs/hr) Ford uses movable'swirl valves' in some of their intake manifold runners. It might also be possible to weld in or drill and tap a custom swirl vane in the top surface of the runners of cylinders 7 and 8. This might give faster burn and slightly less flow. For better MPG, you want higher torque available at lower rpm, with the gearing adjusted to take advantage of that, so that when you are driving at part throttle the vacuum in the manifold is in the 4 to 8 inches of HG range, where fuel efficiency (BSFC) is near optimum. http://autospeed.com/cms/title_Brake-Specific-Fuel-Consumption/A_110216/article.html
[Re: 360view]
#1022201
06/29/11 12:23 PM
06/29/11 12:23 PM
Posts: 3,941 Oregon
hooziewhatsit
I had heard that Hughes changed the angle of the fuel injectors so that they spray more towards the intake valves I've also heard that the stock dodge injectors are single hole, and shoot a pretty solid stream of fuel. By changing to 4 hole injectors that have a much finer mist spray pattern, the fuel is better atomized and burns more completely, improving mileage a hair. Combine the two?
[Re: ptowntsi]
#1022203
07/12/11 12:16 PM
07/12/11 12:16 PM
70Cuda383
Marysville, O-H-I-O
whats the price on those ford injectors?
I've been thinking lately of running E85, and getting an engine tune to run it. that would be a lot cheaper than the premium fuel I'm running now, and still ensure that I'm ping free with the cam, intake, and headers I'm running.
not sure the 24 lb/hr injectors would be big enough though, and would probably run out of flow at WOT above 3500-4000 rpm.
[Re: 70Cuda383]
#3247012
07/24/24 01:40 PM
07/24/24 01:40 PM
Posts: 267 Green Bay
Andyvh1959
Green Bay
As I build my 56 Dodge pickup daily driver, one goal is decent power but also decent fuel economy. The Hughes F1 airgap intake looks promising as a replacement for a modified Kegger on the 5.2 Magnum going into my 56. I also have a 8HP-70 trans to go with it, so I should have good low end torque for crusing on the highway at 70, hopefully to get the revs around 1800 with the 3:55 rear axle ratio. The rear axle is the stock 9.25" limited slip from my 2001 donor Dakota. Getting the crusing revs near 1800 seems to be a sweet spot for good fuel economy, like mentioned above:
This past weeked we did a 600+ mile round trip up to Bayfield WI in our 2019 Kia Sorento. Its got a 3.3V6 rated up to 290hp, and 252 ftlb of torque and an 8 speed trans with a final 3:22 ratio. At 60+ mph it gets about 28mpg on level roads, turning around 1500 rpm. 70+ mph takes about 1800 rpm and still gets over 26 mpg.
Gets me thinking about the Hughes F1 airgap intake to help get the best daily driving mileage from the 5.2.
My 56 C3-B8 Dakota build
[Re: 70Cuda383]
#3247033
07/24/24 02:46 PM
07/24/24 02:46 PM
Andyvh1959
Green Bay
[Re: Andyvh1959]
#3247305
07/25/24 07:11 PM
07/25/24 07:11 PM
Posts: 1,145 rust belt
Moparite
rust belt
The kegger is made to provide power at low rpms. The F1 raises it. The dyno results that Hughes posts are fixed. I seen actual dyno results compared to other manifolds and the kegger makes more power down low. The other manifolds will make more power just at a different rpm. You may want to check this out.
[Re: WO23Coronet]
#3248382
07/30/24 11:20 AM
07/30/24 11:20 AM
Posts: 3,513 DFW
mr_340
DFW
Those dyno sheets don't look right either. Look at the Hughes intake and the M1 2bbl, their torque and horsepower intersect at 5250 RPM like they are supposed to, but the kegger and the M1 4bbl aren't even close, so something is off. I'm no expert but i've learnt that at 5250 RPM, torque and horsepower are supposed to be equal It's just a conversion factor, 33,000/(2*pi)=5252.113.... 33,000 lbs/min=1 HP, 2*pi is the conversion of radians per revolution. This is for HP and lb-ft. The metric system will have a different conversion factor.
Floyd Lippencott IV
[Re: Moparite]
#3248439
07/30/24 03:24 PM
07/30/24 03:24 PM
Posts: 2,796 541 slobovia
A990
541 slobovia
The kegger is made to provide power at low rpms. The F1 raises it. The dyno results that Hughes posts are fixed. I seen actual dyno results compared to other manifolds and the kegger makes more power down low. The other manifolds will make more power just at a different rpm. You may want to check this out. THANKS! I've been looking for Danno's flow chart for years. The Dakota RT board is long gone, and a HD failure dumped my archive copy.
