Using '71/'72 Quarters on a '73? Trunk drop downs? #1019919
06/24/11 09:48 PM
06/24/11 09:48 PM
Manitoba, Canada
O
Overdrive440 Offline OP
O
Manitoba, Canada
Seeing as I can't find a set of quarters for a '73-'74 Road Runner, I am wondering what the difference is between those and a '71-'72?
If there is not much difference, I would be open to getting a new set for a '72 and cutting out what's different and adding that from the '73 assuming the '73 parts are still OK. I mostly need wheel arches and lower quarter replaced, but would prefer working with a full quarter.
Same goes for the trunk drop downs.
Re: Using '71/'72 Quarters on a '73? Trunk drop downs? [Re: Overdrive440] #1019920
06/24/11 11:12 PM
06/24/11 11:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The wheel arches and lower 1/4's are what's different between 71/2 and 73/4. The body line is much more sharp and pronounced around the wheel arches and the 71/2's have an extra body line about 6" up from the bottom of the car, a body line that was smoothed out for 73/4.
Re: Using '71/'72 Quarters on a '73? Trunk drop downs? [Re: DaytonaTurbo] #1019921
06/25/11 11:56 AM
06/25/11 11:56 AM
Manitoba, Canada
O
O
Manitoba, Canada
Well, that kills that idea. That's parts of the quarter that are bad on this car.
Re: Using '71/'72 Quarters on a '73? Trunk drop downs? [Re: Overdrive440] #1019922
06/25/11 12:01 PM
06/25/11 12:01 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
I have one of each in the garage and will second the statement that they are completely different, different enough that you may be better off starting with a slab from a old hood or something.
