Rad fix #1019463
06/23/11 10:52 PM
06/23/11 10:52 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
The overflow spout on my rad poped out.
My thought is to use a propane tourch and solder the spout back on.
Is this the right approach or is there a better / right way to fix this.
Thanks,
Jason
Re: Rad fix [Re: CUDAJAS] #1019464
06/23/11 11:42 PM
06/23/11 11:42 PM
scratchnfotraction Offline
thats how its done,clean clean clean dont over heat and make it soft else where,use a good flux solder and rose bud tip
you could cold weld it with JB weld like i would
good luck
