Will a Sanden compressor fit?
#1019083
06/23/11 01:16 PM
06/23/11 01:16 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I was wondering if a Sanden compressor would fit a small block with a pre-78 intake manifold. I'm looking at getting the brackets off of an 80s m-body and doing the swap on my 78 Fury. The problem is, Im running a dual plane Magnum M1 and it uses the older large thermostat housing. I don't want to change the manifold. Although the Sanden compressors are pretty ugly, id like to use one simply because they're probably quite a bit more efficient than the old RV2.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: Will a Sanden compressor fit?
[Re: 69L78Nova]
#1019085
06/23/11 04:49 PM
06/23/11 04:49 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
They have smaller sandens. I used one while swapping a 440 to a modern ac system. I think they are considered shorty's. Bouchillion sells them for over 200, but ebay sellers, where I got one was around 100.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 68Bullit]
#1019087
06/23/11 07:04 PM
06/23/11 07:04 PM
Challenger 1
Cincinnati, Ohio
Just spoke to a guy at ClassicAutoAir the other day and asked the same question regarding my particular intake (a weiand Stealth on my 360). He told me that the newer Sanden's have mounting hardware that mount the compressor on or around the water pump and in no way touch the intake. Hope this helps.
here's mine on a 340 with Victor340 manifold. It really don't mount on the manifold. I have used 3 different manifolds with this AC, any manifold will work with this setup I got from Bouchillon Performance. There is a rear mounting bracket that bolts to bosses on some manifold that I have used. But like this manifold there are no bosses. I simply used a small stainless peice I had laying around and bolted to the spring return bracket. I have many miles on in this configuration includding 42+ miles on the salt in bonneville at over 100 miles per hour. It ain't pretty but works.
[Re: scratchnfotraction]
#1019089
06/24/11 08:34 AM
06/24/11 08:34 AM
Challenger 1
Cincinnati, Ohio
those are not stock M-body a/c bracket either correct?
bouchillon aftermarket adapt o kit brackets are made to work with intakes that stock brackets do not fit correct?
Correct, brackets from Bouchillon.
