Sagging head liner #1018815
06/23/11 01:39 AM
06/23/11 01:39 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
Any easy fixes
Re: Sagging head liner [Re: theraif] #1018816
06/23/11 01:43 AM
06/23/11 01:43 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
my Dad used a couple strong 1-1/2" - 2" round magnets for the sagging headliner in his 91 dynasty after the dealer couldnt make it "stay fixed"
Re: Sagging head liner [Re: theraif] #1018817
06/23/11 11:08 AM
06/23/11 11:08 AM
crlush Offline
crlush  Offline
Toothpicks, that's what I used on a 88 shadow till I pulled it out and reglued it with spray adhesive, just break the ends off or watch your head while getting in and out.
Re: Sagging head liner [Re: crlush] #1018818
06/24/11 09:59 AM
06/24/11 09:59 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
T-headed fabric pins
are a temporary fix,
and are a little better than ordinary pins as the T presses the headliner upwards over a wider area.
If the headliner is sagging at front or rear this works without looking too bad as the sun shades will hide the heads,
but you can use the T-pins in the middle areas too, and it might even be possible to paint the heads to match the headliner color.
Wall Mart usually stocks them where fabrics are.
Re: Sagging head liner [Re: theraif] #1018819
06/24/11 10:10 AM
06/24/11 10:10 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
stitch it!
