Page 2 of 4 1 2 3 4
Re: Lost all my dash lights tonight where would i start ? [Re: Jim_Lusk] #1016047
06/19/11 02:34 PM
06/19/11 02:34 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It is also easier to work on the dash with the steering column out of the way. I would also be tempted to bypass the rheostat completely and have full voltage to the dash lights.
Re: Lost all my dash lights tonight where would i start ? [Re: Jim_Lusk] #1016048
06/19/11 02:38 PM
06/19/11 02:38 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
You know that was an idea i was thinking as i have never needed to turn down the lights ever!
Hey will the switch come out from the front of the dash??
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016049
06/19/11 03:59 PM
06/19/11 03:59 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just a thought, did you check the fuse for the dash lights and the fuse for the tailights? Either one will kill the dash lights.
Re: Lost all my dash lights tonight where would i start ? [Re: 6PakBee] #1016050
06/19/11 04:16 PM
06/19/11 04:16 PM
Ok i am on that now............. Well as soon as i can muster up the courage to get under the dash as thats where we relocated the fuse panel too.
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016051
06/19/11 05:35 PM
06/19/11 05:35 PM
Ok fuses all good and i pulled the connector out of the switch just to make sure it was tight and plugged it back but still no light. Then i got stuck under the dash and had to have my kids and wife yank me out. Luckly i had my shops come-along handy.
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016052
06/19/11 07:27 PM
06/19/11 07:27 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
STU..
Yank off the 3 tab connector to the dimmer switch, jumper the (2) leads I think they are Orange that went through the dimmer rheostadt. This will send a full 12V to the dash lites. Also check the connector to make sure that 12V is incoming from the headlite switch..
Post back your findings..
Re: Lost all my dash lights tonight where would i start ? [Re: Sinitro] #1016053
06/19/11 07:55 PM
06/19/11 07:55 PM
STU..
I wish i could do that but getting stuck under the dash one time was enough for today...
Can those switches be accessed from the front fo the dash??
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016054
06/19/11 08:45 PM
06/19/11 08:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
STU..
Yes and no......if that darn complete switch plate (with all of the switches) would come out without having to get behind and under the dash yes it would. If you remove the two screws from the back (again not possible without getting on your back under the dash) then you could just unplug it, take the screws out and pull the switch out from under the back of the dash.
I have the dash out right now on the '69 GTX and I fought that switch plate pretty hard and about to put it back in the next few hours; what a PITA. I'm changing the complete underdash wiring harness and been under there for the last two days, not only a PITA but as you said a pain in the back too....Back to your situation there is no way I know of without getting behind and under the dash to get that switch out. Taking out the two screws and pulling the switch out of the back to me at least is the quickest, easiest way but still requires getting on your back.
MikeR
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016055
06/19/11 08:48 PM
06/19/11 08:48 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
STU..
Nope..
You are going to have to lose 50 pounds and about 10 inches from the waistline..
Then slip under the dash, left side of the column..
Can't fix the runner from the patio drinking a beer..
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016056
06/19/11 08:53 PM
06/19/11 08:53 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Why floor dimmer? Headlights are fine. I would focus on the inst fuseand related wiring which you checked, that only get juice when the light switch is turned on. When the inst circuit is working correctly, you can use a standard test light from ground to fuse box inst fuse and see light dim and brighten as you roll the dash dimmer.
Re: Lost all my dash lights tonight where would i start ? [Re: DennisH ] #1016057
06/19/11 09:22 PM
06/19/11 09:22 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Play around with the thumbwheel dimmer switch on the dash. Go past the notch then up and down.
I'd go with the dash dimmer switch.
1981 Dodge D150 360 auto
Re: Lost all my dash lights tonight where would i start ? [Re: basketcase] #1016058
06/19/11 09:30 PM
06/19/11 09:30 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Me too, usually the tab/contact that runs against the springy thing wears or bends and loses contact.....sometimes just in different places but in your case completely. I don't remember if I was able to bend the contact and get one to work before or if it was another brand car.....getting too old or spent too much time under the dash the last two days
MikeR
Re: Lost all my dash lights tonight where would i start ? [Re: A12] #1016059
06/19/11 09:57 PM
06/19/11 09:57 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Stu , i'm no expert , but as far as i'm concerned your high beam dimmer has dik all to do with your dash lights.. only the high beam indicator. If your can confirm that the dash light fuse is ok (and you have 12v there) and that you have the dash light dimmer on its highest point (just before dome light comes on) , i'm saying its the plug where it plugs into your printed circuit board . I bet if you move it around or jiggle it a little, light should work.......providing that all your dash light bulbs never blew .
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016060
06/19/11 09:59 PM
06/19/11 09:59 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Sounds like that maybe the reostat on the HL switch shorted out. Pretty common problem. Bulkhead connector that connects to the hl switch comes loose over time gets hot and shorts out. With your HLs on put your thumb against the switch to see if its hot to the touch. Really only way to tell is reach under and disconnect the connector. If it was loose you'll see some burn marks.
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016061
06/19/11 10:22 PM
06/19/11 10:22 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
my dash lights were a no-go in the 73 Duster, replaced switch, dimmer, bulbs, cleaned the circuit board, checked grounds..all fuses. Guess what? it was the connector on the backside of the fusebox to one end of the fuse, it was corroded. I swapped a nice one from a junk fuse box and wah-la! LIGHTS
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Lost all my dash lights tonight where would i start ? [Re: MonGoo$e] #1016062
06/19/11 11:43 PM
06/19/11 11:43 PM
Mine have been working perfectly since i had the car apart and the rebuilt dash installed. I got all new or rebuilt switches and guages. I also swapped the fuse box so i do not think it's that. Seems more like some type of connection issue or something broke in the switch??
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016063
06/20/11 12:42 AM
06/20/11 12:42 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Not sure on a 69 RR but the instrument cluster is usually grounded thru the screws that hold it to the dash frame. If the screws loosen up you loose the ground.
Re: Lost all my dash lights tonight where would i start ? [Re: Y3 70 BEE] #1016064
06/20/11 01:10 AM
06/20/11 01:10 AM
kentucky
roadrunner7020 Offline
kentucky
Try jumping the dash dimmer switch to test the switch I'll post a picture as soon as possible on what needs to be jumped I lost my lights and have them jumped for now. You'll lose the ability to turn on and off the dome light but it will let you know of the switch is bad
Re: Lost all my dash lights tonight where would i start ? [Re: MidPenMopar] #1016065
06/20/11 01:15 AM
06/20/11 01:15 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Going over bumps in the roaqd has a way of loosening stuff up
Re: Lost all my dash lights tonight where would i start ? [Re: dart4forte] #1016066
06/20/11 01:32 AM
06/20/11 01:32 AM
kentucky
kentucky
This is what you would Jump
Id try this if it works then something is wrong in the switch.
Page 2 of 4 1 2 3 4
