Panhard Bar
#1012969
06/13/11 11:01 PM
06/13/11 11:01 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
Anybody have info on a bracket to attach panhard to 8 3/4 center section? Maybe at the snubber location?
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
Re: Panhard Bar
[Re: poorboy]
#1012971
06/14/11 07:41 AM
06/14/11 07:41 AM
36PLYM
Lithonia, Ga
That was my first choice but the bolts are to short even for 3/16 plate. Are those bolts pressed into the carrier? Thanks.
Re: Panhard Bar
[Re: 36PLYM]
#1012973
07/07/11 09:38 PM
07/07/11 09:38 PM
Posts: 4,282 Florida
blewbyu
Here You Go
Re: Panhard Bar
[Re: blewbyu]
#1012974
07/07/11 09:38 PM
07/07/11 09:38 PM
blewbyu
Here You Go 2
Re: Panhard Bar
[Re: 36PLYM]
#1012975
07/07/11 10:25 PM
07/07/11 10:25 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One of the reasons a panhard rod isn't optimal is that it tends to move the housing side to side as it goes up and down. To lessen the effect you want a panhard rod to be as long as possible. I would attach it to the axle flange on the axle end if at all possible.
Or, if you want to eliminate the problem altogether, use a watts linkage.
