Re: How do I test my clutch fan?
[Re: mopar346]
#1012876
06/13/11 11:48 PM
06/13/11 11:48 PM
Posts: 7,664 IN
ahy
IN
I don't believe it ever actually locks up. Get it hot and running at idle then cut it off the fan should stop with in a few seconds or a few rounds. With the engine off but hot, spin the fan be hand, it should have a reasonably amount of resistance and it should only spin about 1-1.5 rounds when you spin it with some force. With the car off grab the fan and check the bearing for slack. If it fails any of these I would replace it.
A 1970 would likley have a "thermal" fan clutch. It has a little coil in front that senses temperature and tends to engage or "lock up" meaning it slips less when hot. If it fails the tests above, replacement is needed. My one experience with parts store clutches on a DD - torqflow brand - was not good and I went with OE. The MP re-pop setup from Mancini works well on my 1970E. The kit I used comes with a 5 blade "low drag" fan which worked fine in my application, however, with cooling problems I would go with the OE fan which is usually bigger/more aggressive or an even bigger fan like the 7 blade used on mid/late 70's BB Chrysler's (JY) or the 6 blade fan from Bouchillon.
[Re: ahy]
#1012877
06/14/11 01:00 AM
06/14/11 01:00 AM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
While the engine is off, grab a fan blade at the 12:00 position and hold it firmly. Have someone start the engine (while you are still holding the fan blade and keeping it from turning) and take the engine to 2,000 rpm's and hold it steady. Let go of the fan blade and the fan and clutch should catch up to the 2,000 rpm's within a few seconds. If it does not - then it's not working correctly.
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: WyleECoyote]
#1012878
06/14/11 01:32 AM
06/14/11 01:32 AM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
........oops forgot I don't have a clutch fan
[Re: WyleECoyote]
#1012879
06/14/11 09:07 AM
06/14/11 09:07 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
While the engine is off, grab a fan blade at the 12:00 position and hold it firmly. Have someone start the engine... and take the engine to 2,000 rpm's...
Ummm. You hold it and I'll start it....
[Re: JeffRacerG]
#1012881
06/14/11 05:39 PM
06/14/11 05:39 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When it comes to fan clutches the factory says the only way to test a unit is to replace it with a known good unit.....I totally agree.
[Re: WyleECoyote]
#1012882
06/14/11 06:01 PM
06/14/11 06:01 PM
Posts: 106 Poland
willard
Poland
If I did that with my fan, I'd probably lose a few fingers. My fan clutch seized and acted like a solid spacer.
[Re: willard]
#1012883
06/14/11 06:36 PM
06/14/11 06:36 PM
Posts: 1,012 indiana
mcmopars
indiana
i tried that with my lawn mower,once,once
[Re: JeffRacerG]
#1012885
06/14/11 07:26 PM
06/14/11 07:26 PM
Challenger 1
Cincinnati, Ohio
I can hear mine working, like when I get off the hi-way and come to a stop. Then when I take off I can hear the sound of my fan, it's louder. Then as it cools off the fan get's quiet again. I have had 2 car's over the years that overheated at slow speeds or idle, both times new fan clutches fixed my problem and I could hear the fan again when it was hot. I have a 7 blade stock fans.
[Re: willard]
#1012886
06/14/11 10:49 PM
06/14/11 10:49 PM
WyleECoyote
Tennessee
Okay - STEP 1 - Make sure clutch fan isn't seized and is free turning (see schematic).....
[Re: Commando1]
#1012888
06/15/11 12:10 PM
06/15/11 12:10 PM
Posts: 4,799 ILL
MLR426
ILL
no you hold it and I'll start it
logan426
