Fan shroud to rad. hard ware needed #1011594
06/12/11 02:49 AM
06/12/11 02:49 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Where can I get fan shroud to radiator hardware? I need the extruded nut(4)(clips on Radiator) and screws (4). Where can I find these items?
Re: Fan shroud to rad. hard ware needed [Re: bigblock340power] #1011595
06/12/11 03:07 AM
06/12/11 03:07 AM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
i think Mancini's has them
Re: Fan shroud to rad. hard ware needed [Re: CUDAJAS] #1011596
06/12/11 12:53 PM
06/12/11 12:53 PM
Elk Grove, Calif.
Elk Grove, Calif.
Nope they don't. This is what I'm looking for. Anybody?
Re: Fan shroud to rad. hard ware needed [Re: bigblock340power] #1011597
06/12/11 01:09 PM
06/12/11 01:09 PM
Shoreline, Washington
72roadrunnergtx Offline
Try Rocket Restorations , I have purchased a set of those from them in the past. Pretty sure it's kit #8197
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Fan shroud to rad. hard ware needed [Re: 72roadrunnergtx] #1011598
06/12/11 01:44 PM
06/12/11 01:44 PM
Elk Grove, Calif.
Elk Grove, Calif.
Thanks, No pics on his web page, so I sent him an E mail W/pics. It was #8197.
We'll see.
Re: Fan shroud to rad. hard ware needed [Re: bigblock340power] #1011599
06/12/11 02:11 PM
06/12/11 02:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
At any auto parts stores, called U nut's.
Re: Fan shroud to rad. hard ware needed [Re: bigblock340power] #1011600
06/12/11 04:41 PM
06/12/11 04:41 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I got them from this guy: INSTOCK102@aol.com
Re: Fan shroud to rad. hard ware needed [Re: 72roadrunnergtx] #1011601
06/13/11 05:12 PM
06/13/11 05:12 PM
Elk Grove, Calif.
Elk Grove, Calif.
He doesn't have them anymore.
As per his quote: Sorry but our vendor discontinued 8197 and we are no longer able to get it. I need them bad people.
Re: Fan shroud to rad. hard ware needed [Re: bigblock340power] #1011602
06/13/11 05:28 PM
06/13/11 05:28 PM
Worcester, Mass
68goldfish Offline
68goldfish  Offline
Worcester, Mass
I went to my local FinishMaster. They carry all of that type of hardware. They let me search the bins. Found the correct Bolts, and some close enough spring clips. When I brought them to the counter, they told me since I did the search, I could have them for free!
Re: Fan shroud to rad. hard ware needed [Re: bigblock340power] #1011603
06/13/11 05:52 PM
06/13/11 05:52 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Try rob1426 on EBay - that's where I got mine.
Re: Fan shroud to rad. hard ware needed [Re: IronWolf] #1011604
06/13/11 06:22 PM
06/13/11 06:22 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I just bought some from Dave @ Totally Auto. It's a mopar restoration shop that happens to be down the street from my business. They have all the little bolts and stuff I ever needed and always reasonably priced and way more correct than I care about.
He's on Philmont in Bensalem PA- the website should be easy to find too.
Good Luck!
rdr
Re: Fan shroud to rad. hard ware needed [Re: radar] #1011605
06/13/11 07:01 PM
06/13/11 07:01 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Mike,
Have you ever been to the Emigh Hardware store in Sac? At the corner of El Camino and Watt - they have everything. Might be worth the trip if you really have to have it NOW
Chris
Re: Fan shroud to rad. hard ware needed [Re: Morty426] #1011606
06/13/11 08:34 PM
06/13/11 08:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I have the screws and a generic U nut clip.
the correct flat U clip is on a major backorder thru the manufacturer
Re: Fan shroud to rad. hard ware needed [Re: gtx6970] #1011607
06/13/11 08:46 PM
06/13/11 08:46 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
You would be surprised at just what Ace hardware and others like them have. Don't ask the counter person unless they know what is what. Just go look through the hardware trays you will find plenty of those extruded sheet metal nuts. Many other clips and such people think they have to order from some where, after all bolts is boltsRight?
Re: Fan shroud to rad. hard ware needed [Re: bboogieart] #1011608
06/13/11 09:06 PM
06/13/11 09:06 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I have them in stock and ready to ship.
http://cgi.ebay.com/ebaymotors/fan-shrou...sQ5fAccessories
Re: Fan shroud to rad. hard ware needed [Re: badblack68] #1011609
06/13/11 11:02 PM
06/13/11 11:02 PM
Elk Grove, Calif.
Elk Grove, Calif.
Bought um! Thank you!!! Now ship them as fast as you can.
Again, thank you very much,
Mike
