440 Oil Pan and Pickup Help #1011243
06/11/11 09:02 PM
06/11/11 09:02 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I am building a 440 and went to put the pan and pickup on today and the pickup interferes with the pan. I am using a cheap chrome baffled pan and a straight pickup. The pickup does not interfere with the baffles but with the rearward bottom of the sump right by the drain plug like the sump doesn't go back far enough. The pickup hits there not allowing the pan to fully seats. Is there anything I can do?
In this picture you can just see the oil pan on the floor.
Re: 440 Oil Pan and Pickup Help [Re: bordin34] #1011244
06/11/11 09:40 PM
06/11/11 09:40 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Whoever makes yor oil pan probably makes the pickup you'll need. What pickup do you have?
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: 440 Oil Pan and Pickup Help [Re: HitIt] #1011245
06/11/11 11:01 PM
06/11/11 11:01 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Re: 440 Oil Pan and Pickup Help [Re: bordin34] #1011246
06/11/11 11:07 PM
06/11/11 11:07 PM
That looks like my garage (ex for the alum heads)
Re: 440 Oil Pan and Pickup Help [Re: RapidRobert] #1011247
06/12/11 09:39 AM
06/12/11 09:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's cleaner than mine , too much open floor showing ...
Re: 440 Oil Pan and Pickup Help [Re: JohnRR] #1011248
06/12/11 03:57 PM
06/12/11 03:57 PM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
Re: 440 Oil Pan and Pickup Help [Re: bordin34] #1011249
06/12/11 05:09 PM
06/12/11 05:09 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The OEM type pick up, like the one you link to, is supposed to have a slight interference fit and contact the pan's floor.
Do you run a windage tray? If you don't, get one. The thickness of the tray and extra gasket may give you the clearance you need.
Three other options;
1-Add more threads with a 3/8" pipe die and trim the end so you can screw it in further.
2-Bend the tube up.
3-Buy a better pan, with matching pick up, that holds more oil than the 4qt one you have, yet doesn't hang down like the 8qt 7" deep pan, that's the MP repoped 6qt '70-'72 440HP/Hemi pan.
Re: 440 Oil Pan and Pickup Help [Re: B5 Bee] #1011250
06/12/11 05:51 PM
06/12/11 05:51 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Thanks, I think I am going to run the 402 pan that is currently on my charger instead of modifying things to make this one fit.
