torsion bar remove and replace #1008864
06/07/11 09:38 PM
06/07/11 09:38 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Going to replace my torsion bars with 1.03 bars, any tips or shortcuts on removing the old ones. Do I need the specialty tool or can I get by without one. Any tips or advice is greatly appreciated. Thanks, Charlie.
Re: torsion bar remove and replace [Re: cudachas] #1008865
06/07/11 09:50 PM
06/07/11 09:50 PM
No need for the tool. Trick is to get as much weight off of it as possible (tire/wheel) & take out the adj bolt/square block w notches/clip in rear crossmember hex socket & take off the front nut on the tapered LCA shaft & tap it back to start the whole shebang going rearward a bit then go to the other side to the LCA hex & tap it (lca hex) back forward to get the front hex of the Tbar coming out/free. On a stubborn one can clamp a large vice grip on it w ENOUGH INSULATING MATERIAL so the serrations do not damage the Tbar. #1 get the angle straight/load off of it. W the car on stands then a small hyd jack under the LCA to get the angle/load right
Re: torsion bar remove and replace [Re: RapidRobert] #1008866
06/07/11 10:00 PM
06/07/11 10:00 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
The car is on stands and the wheels, and brake rotors are off the car. I backed the adjuster all the way out. Should I disconnect the shock or will it allow the LCA to move backward enough while still connected.
Re: torsion bar remove and replace [Re: cudachas] #1008867
06/07/11 10:11 PM
06/07/11 10:11 PM
undo bottom end or take em out if need b
Re: torsion bar remove and replace [Re: cudachas] #1008868
06/07/11 10:41 PM
06/07/11 10:41 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I agree on losening the pivot shaft nut on the LCA...makes a big difference.
Are these the PST 1.03" bars? What are you putting them in? If they are, they suck....they're not clocked differently from one end to the other and you lose all adjustability. But I tried them in a '70 'Cuda so something else "may" be different...
FYI I went with the Mopar Perf. 0.96" bars and love them
Re: torsion bar remove and replace [Re: RapidRobert] #1008869
06/07/11 11:53 PM
06/07/11 11:53 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Or if you are junking the old bars, just clamp the vice grips on them and
Ride eternal, shiny and chrome
Re: torsion bar remove and replace [Re: DirectSubjection] #1008870
06/08/11 05:29 AM
06/08/11 05:29 AM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Yes they are the PST 1.03 bars going in a 70 cuda. I did not hear that about those bars otherwise I would have passed on them.What happened,you could not adjust your ride hight when you installed them? did you run out of adjustment?
Re: torsion bar remove and replace [Re: cudachas] #1008871
06/08/11 11:12 PM
06/08/11 11:12 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Yes, I ran out of adjustment completely. PST claims that the larger diameter doesn't need as much "pre-load" which is how they explained the reasoning for both ends of the torsion bar being clocked the same. The have to be offset. If they are not, when you install them you will run out of adjustability and your car will be sitting low....which is ok if you like the look and NEVER want to adjust them up...
The only other thing to do is put enough pressure on the LCA to raise it up enough to line up with the torsion bar again...and now it will be waaaaay too high and you still won't have adjustability.
You are more than welcome to try them, and if they don't work out for you, I have the contact of the guy I dealt with, he was really cool and refunded everything including shipping. In return I bought the MP 0.96" bars off of them as replacements.
Re: torsion bar remove and replace [Re: JoesMopar] #1008872
06/09/11 04:53 PM
06/09/11 04:53 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Thanks J5440 , you were correct. Heres the story. I loosened the LCA nuts and tapped the arm back enough to R&R the torsion bars, went pretty easy. Car is on the ground and I had to run the torsion bar adjusters all the way in with no more adjustment available. I have about 3/4" of gap between the LCA snubber and the frame with a ride hight that I can live with but I would not want it any lower. I did not drive the car yet as the weather does not look good here.I have an appointment for an alignment on saturday and I will report back. Thanks everyone for the advice it was a great help. Charlie.
Re: torsion bar remove and replace [Re: cudachas] #1008873
06/09/11 10:36 PM
06/09/11 10:36 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
No problem, hope it works out for you.
Re: torsion bar remove and replace [Re: JoesMopar] #1008874
07/29/11 03:37 AM
07/29/11 03:37 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Just noticed this post. I have the PST 1.03's and have the same adjustment nissue, except mine is compounded by the fact I have 2" drop spindles. My next step is to try backing the hex off a whole flat upon re-installation.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
