Braking Problem #1007327
06/05/11 06:47 PM
06/05/11 06:47 PM
S.E. MICH.
Demonizer Offline OP
S.E. MICH.
Just got my car out of winter storage today and I'm experiencing a braking problem. It was converted to large bolt front disk brakes about 4 years ago using the parts from a 1974 Dart. When I went to brake comming out of the trailer the brake light on the dash came on and the petal went nearly to the floor. I can pump up the petal to stop but It goes right back down after that,(fluid is full). Could it be the proportining valve. Everything worked fine when I put it away for winter.
Re: Braking Problem [Re: Demonizer] #1007328
06/05/11 06:51 PM
06/05/11 06:51 PM
BDW Offline
BDW  Offline
You have a leak somewhere. Take a close look at MC, and take off each wheel and inspect.
Re: Braking Problem [Re: Demonizer] #1007329
06/05/11 06:57 PM
06/05/11 06:57 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
if the pedle goes to the floor but not lousing fluid has to be master cly. the fluid bleeds by the seal in side all the fluid stays in the master. the stm. was full of fluid neve emty if was emty air will make this hapen to.
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Braking Problem [Re: Demonizer] #1007330
06/05/11 06:59 PM
06/05/11 06:59 PM
Air. Bleed the m/c then the wheels in order if that dont make the pedal high & tight. the light coming on says there's a pressure differential in one half of the system which may b the m/c but do check the wheel cyls for leaks
Re: Braking Problem [Re: RapidRobert] #1007331
06/05/11 09:18 PM
06/05/11 09:18 PM
S.E. MICH.
S.E. MICH.
Thanks to all for the help. I will try bleeding the system first chance I get. Just thought it was funny, braking system worked fine when i put it away for winter storage.
