Lunati voodoo 60303 and power brakes?? #1007187
06/05/11 03:45 PM
06/05/11 03:45 PM
Jacksonville, NC
RonP Offline OP
RonP  Offline OP
Jacksonville, NC
Hey folks, just have to finish brake system and build engine/trans and I will finally have my satellite on the road.
I have this cam and it will be a 440 based 493 with edlebrock heads about 10:1 compression. I want this to be a completly streetable car.
I am putting power brakes back in the car as my dad removed the booster years ago because of an agressive cammed engine.
So will this cam work with power brakes?
specs: http://www.lunatipower.com/Product.aspx?id=1579&gid=287
Re: Lunati voodoo 60303 and power brakes?? [Re: RonP] #1007188
06/05/11 04:32 PM
06/05/11 04:32 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
They'll work fine, that's a pretty mild cam.
Re: Lunati voodoo 60303 and power brakes?? [Re: 440newport] #1007189
06/05/11 05:29 PM
06/05/11 05:29 PM
Jacksonville, NC
RonP Offline OP
RonP  Offline OP
Jacksonville, NC
I figured it would but wanted some opinions as my other stuff is just a little more agressively cammed.
Re: Lunati voodoo 60303 and power brakes?? [Re: RonP] #1007190
06/05/11 05:45 PM
06/05/11 05:45 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You sure you want to put that tiny cam in 500ci build? Yes, it will work power brakes.
Re: Lunati voodoo 60303 and power brakes?? [Re: goldmember] #1007191
06/05/11 05:48 PM
06/05/11 05:48 PM
Jacksonville, NC
RonP Offline OP
RonP  Offline OP
Jacksonville, NC
well the thing is I already have it. Was just going to run a 440 in it, but have since decided on a 500. The thing is I really want it to be streetable as in if I want to drive it 400 miles to PA on leave, i can. Just want it to sound good and look good.
I have some time and I guess I can look into unloading this one and moving up a couple steps.
Re: Lunati voodoo 60303 and power brakes?? [Re: RonP] #1007192
06/05/11 11:25 PM
06/05/11 11:25 PM
IN
ahy Offline
ahy  Offline
IN
Agree no problem on the PB. I'm running a [Email]243@.050[/Email] intake duration/108 CL cam and PB work. 13" idle vacuum and much higher on deceleration.
This is on a 496 with 10.2 CR.
