340 w/ electronic ignition starting problem
#1005959
06/03/11 05:26 PM
06/03/11 05:26 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Trying to get my '70 340 running in an E-Body and it will not start. Seems to want to fire when you let off the key, so I tried a new ballast resistor and still no go. Is it the ignition switch? Any other ideas?
Mo' Farts
Moderated by "tbagger".
Re: 340 w/ electronic ignition starting problem
[Re: Moparmedic440]
#1005961
06/03/11 09:55 PM
06/03/11 09:55 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I had the opposite problem once. The engine would only run as long as the key was on start with the starter spinning. When you let the key go back to run, the engine died. That was a bad ballast resistor.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Moparmedic440]
#1005962
06/04/11 01:44 AM
06/04/11 01:44 AM
Posts: 6,018 Salem
Grizzly
Salem
Thanks, 'Medic, I'll follow that wire and see if there is a short.
I did order a new ignition switch.
Mo' Farts
[Re: RapidRobert]
#1005966
06/05/11 04:58 PM
06/05/11 04:58 PM
Posts: 6,018 Salem
Grizzly
Salem
Thanks for all the replies, everyone. I will try everything and start with the ignition switch as soon as it gets here.
Mo' Farts
