Re: Expensive but effective way to fix detonation??
[Re: Spraygoon]
#1005631
09/25/11 06:00 PM
09/25/11 06:00 PM
Posts: 81 Oklahoma City
Spraygoon
Oklahoma City
Car is back together and I think mom would be proud ( she passed away in March and she bought me some car parts!). Used the stealth aluminum heads and left the pistons alone (KB237), used a .020 Cometic gasket that gave me .040 quench, Dist is set up with Vacuum advance running on manifold vacuum which give it 30 degrees at idle, mechanical is all in @ 3000 @ 34 degrees, 1.7 rockers on the exhaust, Mcleod diaphragm clutch, new flywheel, aluminum driveshaft, FBO dist recurve and ignition and a ton of little stuff I hope to forget soon. Stock six pack jetting, may go up a size. Final compression was 10.2 with an 85 cc chamber. The way it runs now is unbelievable, once the tach hits about 2200 the tone of the exhaust begs you too nail it. Slight gas smell at idle but not bad. I have run about 1/2 tank of 93 through it and there is not a hint of detonation and plugs read just right. My only regret is not doing it sooner and giving my mom a ride. Thanks to all.
[Re: Spraygoon]
#1005632
09/25/11 10:38 PM
09/25/11 10:38 PM
RapidRobert
Paul glad that ended up working out well. Did you have anyone check over the guide/seats/valves or were they left untouched.
[Re: Spraygoon]
#1005634
09/26/11 10:16 AM
09/26/11 10:16 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
I also had to shim the rocker shafts .060 to make the pushrods work out. Not real sure why that was necessary since theoretically I only dropped the head .017 which is the difference between the .037 Fel Pro and the .020 Cometics but it works.
You did that WRONG , you need to look at the wear pattern of the rockers to the valve tips , if you didn't have a geometry problem you may now , you really need shorter pushrods , ASSuMEing the geometry of those heads is correct to begin with.
[Re: JohnRR]
#1005635
09/26/11 10:50 AM
09/26/11 10:50 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
with those 1.7's I would have had a set of push rods custom made.
