1989 5.2 b150 black smoke #1004549
06/01/11 05:35 PM
06/01/11 05:35 PM
Toronto, Ont, Canada
boydsdodge Offline OP
Hey all, any of you have any knowledge on 5.2 throttle bodies? This is on my work truck that has been very dependable for years until now and it's needed greatly for or work.
Mine won't start unless I floor it and then it's a huge cloud of black smoke and stays that way after it starts.
As I crank it over watching the throttle body it is dumping way to much fuel during the cranking.
I have tried a new MAP sensor but no change.
If anyone has an answer for this please pass it on.
Thanks.
Re: 1989 5.2 b150 black smoke [Re: boydsdodge] #1004550
06/01/11 06:04 PM
06/01/11 06:04 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
When you crank engine, can you see each injector pulse back and forth? or does one injector just seem to not turn on and off while cranking? I ask because I've heard of o-ring failure that lets fuel pour around injector, instead of going through it.
Re: 1989 5.2 b150 black smoke [Re: buildanother] #1004551
06/01/11 06:43 PM
06/01/11 06:43 PM
Throttle blades below the two injectors are almost closed but the injectors seem to want to dump a 1/4 mile pass into the engine.
I just did another look and got a face full of atomized fuel, blaaayuk.lol
The injectors seem to be doing there job of spraying equally but just too much.
This was a sudden thing that happened with the engine no warning after a month of rain but nice and dry now.
Re: 1989 5.2 b150 black smoke [Re: boydsdodge] #1004552
06/01/11 06:50 PM
06/01/11 06:50 PM
chicagoland,usa
chicagoland,usa
Have you done the on-off-on-off-on thing with the key yet to check trouble codes?
Re: 1989 5.2 b150 black smoke [Re: buildanother] #1004553
06/01/11 07:27 PM
06/01/11 07:27 PM
I don't know how many times to do the on off code check.
Re: 1989 5.2 b150 black smoke [Re: boydsdodge] #1004554
06/01/11 07:44 PM
06/01/11 07:44 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Super rich is often ECT.
Check codes and check the sensor up near the thermostat.
Re: 1989 5.2 b150 black smoke [Re: RodStRace] #1004555
06/01/11 08:12 PM
06/01/11 08:12 PM
Do you have the steps for checking code with key?
Thanks for the tips on the coolant sensor.
Re: 1989 5.2 b150 black smoke [Re: boydsdodge] #1004556
06/01/11 09:27 PM
06/01/11 09:27 PM
chicagoland,usa
chicagoland,usa
Put key in ignition, then turn it to on, then to off, then to on, then to off, then back to on, all in like 4 seconds total time, then count flashes of eng lamp.
Re: 1989 5.2 b150 black smoke [Re: buildanother] #1004557
06/01/11 10:51 PM
06/01/11 10:51 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
3 times off and on, last time leave it on. get a pen and write the flashes. all of them are 2 digit codes. (if you miss one, just redo the test, after the codes are done flashing. it doesnt erase itself after you run the test) the squirts should be so tiny, as to be almost invisible when cranking and at idle. and you should easily be able to see the pulses moving from left to right sides. if it's anything more than just a tiny wisp of fuel something is wrong with the injector, or the signal being sent to it.
Re: 1989 5.2 b150 black smoke [Re: RodStRace] #1004558
06/03/11 11:02 AM
06/03/11 11:02 AM
Thanks all for the tips, I got it going.
I had changed out the MAP sensor earlier in the day with no change, unless it takes MAP sensors a while to get going.
So under the advice of RodStRace I checked out the ECT sensor,
Took the plug off cleaned it up and reinstalled.
Truck ran much smoother but still very smokey, let it get up to op temp.
No smoke at idle only on revving engine, took truck for drive on the Hiway and it cleared up as I drove.
Runs great, starts fast and clean, Thanks again for the suggestions.
Re: 1989 5.2 b150 black smoke [Re: boydsdodge] #1004559
06/03/11 11:08 AM
06/03/11 11:08 AM
Indiana
P
Pentastar440 Offline
P
Indiana
Throttle position sensor.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 1989 5.2 b150 black smoke [Re: Pentastar440] #1004560
06/03/11 05:17 PM
06/03/11 05:17 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
had a similar problem on 89 B series 5.2, was O2 sensor,rough choppy idle,would almost die,ran hot,miss with load....
