Page 2 of 4 1 2 3 4
Re: SB Edelbrock LA heads 304cfm@.600" [Re: W5DART66] #1003468
06/01/11 10:03 PM
06/01/11 10:03 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
mopster, nice work
I am curious as to what the Indybrock port looks like. mopsters ports look like alot of work when you can just use offset rockers and lose the pushrod pinch but i have never seen a picture of the port and would like to if someone could share
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003469
06/01/11 10:03 PM
06/01/11 10:03 PM
detroit area
moderncylinder Offline
detroit area
the epoxy in front of the guide will create an "anti" swirl to the natural pattern of swirl natural to the valve placement/position... ls motors have that cast in,,, you can get turbulant airflow, or air disconnecting from the short turn and the vane,, or a particular type of valve job will help the air stay connected as valve lift goes up. everyone has seen air get turbulent or a head loose airflow as lift increases,, what he did with the epoxy will help that not to happen,, and for the head to continue to gain as lift increased
putting more short side on the head with epoxy is not a bad idea..
Re: SB Edelbrock LA heads 304cfm@.600" [Re: sixpackgut] #1003470
06/01/11 10:38 PM
06/01/11 10:38 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
mopster, nice work
here is a CNC Indybrock port
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003471
06/02/11 08:57 AM
06/02/11 08:57 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Mopster that looks good to me,and numbers are inline with what that much effort should give. the man that ported my edelbrocks didnt have much good to say about the sb edelbrock ports out of the box,the only thing he liked about them was that atleast they where not cast iron.
i gues those wings around the valveguide is to keep the airflow away from the exhaustvalve and minimize the amount of fresh fuel/air from taking a shortcut out into the exhuast during overlap?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003472
06/02/11 09:37 AM
06/02/11 09:37 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
304 CFM or not, professional porter or not, uniform work with epoxy is not easy.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: S/ST 3040] #1003473
06/02/11 10:09 AM
06/02/11 10:09 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Looking at your work I imagine these are the not first set of heads you've ported. Nice looking work!
Alan Jones
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003474
06/02/11 10:56 AM
06/02/11 10:56 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Looks like you did a lot of work developing what you wanted.I,for one,can appreciate the need/want to do things yourself.
Please,keep us posted on the rest of the build!
Keith
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Dunnuck Racing] #1003475
06/02/11 12:12 PM
06/02/11 12:12 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Nice work and I have no doubt your numbers are good judging from the amont of work I see in the shots. Also you have your base numbers for comparison which always make it easier to compare flow numbers to other benches.
What has always been interesting to me is hardly anyone talks about wet flow and that if you consider a (for example) 12:1 A/F ratio at 300cfm, 7.6 or so percent (or 23 cfm of that 300) is displaced by the Liquid Fuel in suspension and fuel doesn't always act or swirl around in the port exactly the same way that air can or does. Also everyone understands say 300 CFM for port comparison but how many think about that intake valve being shut for around 2/3'rds of that minute?
Even the more we know, we still learn more from "cause and effect." I've seen similar epoxy mods that picks up the airflow big on the flow bench but don't always correlate to a proportional increase in power. Also a port that doesn't work well with a carb may work extremely well with port injection (related to that very reason).
Ryan said something very insightful (I'm paraphrasing) that he doesn't neccessarily concentrate on the flow on the bench so much if you know from experience where to port to pick up the power...in the end that's really the bottom line becuase nobody races flowbenches
Take your intake duration at .050 and divide that by 720, take that fraction and multiply it by 60, that's how many seconds per minute your intake valve is actually open....and Unless I missed something that is constant regardless of RPM i use this to compare 2 cams @ .050 and .0200 becuase it gives you a 'real world" relative percentage comparison from one to the other.
WIZE
In Car:
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Streetwize] #1003476
06/02/11 12:36 PM
06/02/11 12:36 PM
SoCal
Brian Hafliger Offline
SoCal
Thanks alot for the pics. I'm doing a pair right now and I'll post pics of mine this weekend...they are right at 302cfm at .650.
It's just fun to share...that's what this site was all about a few years ago...
Brian
Brian Hafliger
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Streetwize] #1003477
06/02/11 08:36 PM
06/02/11 08:36 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
About the epoxy mod around the guide; itīs there to keep the port not stalling at higher lifts, just as moderncylinder said. I think It depends entirely of the port shape if it works or not. I wasnīt planning to do it at the beginning, but the way the port ended up, I felt it must be done. I Didnīt do any flowbench testing with that so I canīt be absolutelu sure if itīs needed. In fact, I didnīt do any flowbench testing with the port shape at all, I only tested a few variations in seat work.
I got the intake done today. It was a lot of grinding too, I had to remove about 25cc from each port to get the size right. Hereīs a pic I took earlier. Who recognizes the intake?
OU812, Iīm looking forward to see your work.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003478
06/02/11 08:44 PM
06/02/11 08:44 PM
S/ST 3040 Offline
S/ST 3040  Offline
An M-1 tunnel ram?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: S/ST 3040] #1003479
06/02/11 08:52 PM
06/02/11 08:52 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Bingo.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003480
06/04/11 08:13 AM
06/04/11 08:13 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
I was just finishing the seat work to match the best flowing port I tested, and I thought of something... This port was my "wild card" and I didnīt expect it to be the best one, and beside the seat, it actually had one another thing different than the other ports. I have been doing some studying now with the flow sheets,and compared them to results I got from similar testing with another set of heads, and I think that this another thing is actually hurting the flow.
I arranged some flowbench time for tomorrow, and Iīll report when I have new results. I donīt know if I will gain anything, but I must do this or I canīt sleep at nights
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003481
06/05/11 11:57 AM
06/05/11 11:57 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Didnīt gain more flow, but I found out it wasnīt the seat that made the port better but this other thing, which was slightly different short turn shape. Now Iīm going to even them out and thats it, no more testing.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: moderncylinder] #1003482
06/05/11 04:07 PM
06/05/11 04:07 PM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
ive done magnum heads that are for super stock, 180 cc int runner, 2.020 valve,,, flow 285-290,, on a .060 over 360, 12/1, fuel injected make 685hp,, guy just set the record in ss/ia this past weekend,, in a 3200lb car or so went 9.62 at about 85% throttle,, ran high 9.40's at 3300lbs at 100% throttle
Nice job, are intake port and bowl in the Edelbrock Magnum head similar at all to the Mopar Magnum RT iron head?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: LSP] #1003483
06/05/11 07:46 PM
06/05/11 07:46 PM
detroit area
detroit area
no
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003484
06/08/11 01:34 AM
06/08/11 01:34 AM
SoCal
SoCal
Here's some pics...
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003485
06/08/11 01:45 AM
06/08/11 01:45 AM
SoCal
SoCal
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003486
06/08/11 01:48 AM
06/08/11 01:48 AM
SoCal
SoCal
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003487
06/08/11 01:50 AM
06/08/11 01:50 AM
SoCal
SoCal
Page 2 of 4 1 2 3 4
