Can an ECU burn out a coil or is it vice versa?
#1002987
05/30/11 02:30 PM
05/30/11 02:30 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Long story short.... Cruising along the '69 decided to sputter & stall out....crank no start on the side of the road.
Checked the obvious wiring etc & all looked good. Unplugged my FBO ign module & plugged in my spare orange box with a ground lead....car fired right up.
Swapped in the orange box permanently on the side of the road....no start again! This time I swapped in a spare coil....car fired right up with spare coil & module.
For shitz & giggglez & re-swapped back in the FBO module on the side of the road & nothing...crank no start.
Get the car home for more diag work. Now I swapped back in the FBO coil....starts no problem now. Swapped in the FBO ECU...no start.
So now my dilemma....whats up with the coils? When I got home after the ordeal the Mopar resto coil was really hot....I am running the MSD ballast that FBO provides with their kit....need to go back to a "stock" ballast to keep "stock" coil cool?
1MYTGTX
Re: Can an ECU burn out a coil or is it vice versa?
[Re: 1MYTGTX]
#1002988
05/30/11 03:18 PM
05/30/11 03:18 PM
RapidRobert
Yes a given ECU type can only switch so much pri current which as you know is the coil/ballast resistances in series (added together) plus a given coil type can only handle so much current from a particular ballast. Sounds like the FBO ECU went bad & yes the FBO ballast will prob flow too much for the OE coil. Use your MP ballast w the MP coil but post your ohm amts as you do have some leeway
[Re: RapidRobert]
#1002989
05/30/11 03:42 PM
05/30/11 03:42 PM
1MYTGTX
S.I. N.Y.
Ok thanks....
I did swap back in my old setup I was running...Chrome box, resto coil & stock ballast which was .6 ohms
The MSD unit that comes with the FBO kit was .8-.9 ohms
Also measured resistance on the coils...from the center tower to either post I got 10.xx ohms out of the FBO coil & 12.xx ohms from the resto coil. Not really sure how to test a coil though....
1MYTGTX
[Re: 1MYTGTX]
#1002992
05/30/11 10:33 PM
05/30/11 10:33 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I was running a MP chrome ECU, Accel 8145 coil and 1.2ohm ballast, never had a failure.
I decided to try the FBO 688 ignition for a possible performance gain. I lost 2 ballast the first 150 miles, 50 miles later the FBO ECU went, replaced it with the original MP chrome, 50 miles later I lost another ballast, then 50 miles after that my original MP chrome. Only thing left was the FBO coil. Thinking the FBO coil was the problem, I changed it for the Accel 8145 along with another MP chrome, everythings been good for the last 20,000+ miles.
[Re: NachoRT74]
#1002998
06/01/11 04:59 PM
06/01/11 04:59 PM
Paul_Fancsali
