1971 Hemi Tranny cooler Mounting? #1002599
05/30/11 01:15 AM
05/30/11 01:15 AM
Fargo ND
moparphilll Offline OP
Fargo ND
Does anyone have a good photo of how the tranny cooler mounts on a 1971Hemi RR?? Thanks
Re: 1971 Hemi Tranny cooler Mounting? [Re: moparphilll] #1002600
05/30/11 11:31 AM
05/30/11 11:31 AM
Fargo ND
Fargo ND
Correct???
Re: 1971 Hemi Tranny cooler Mounting? [Re: moparphilll] #1002601
05/30/11 11:44 AM
05/30/11 11:44 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Not quite, but close. The two upper "tabs" go on the engine side of the support. There is a indent on the radiator frame that holds the tabs between the support and the rad. The two lower mounts use body mounting bolts to hold that to the bottom of the support. If I had a photo of that I would send, but I'm redoing the car and it's apart.
Re: 1971 Hemi Tranny cooler Mounting? [Re: DANA60] #1002602
05/30/11 01:43 PM
05/30/11 01:43 PM
Fargo ND
Fargo ND
Ok I'll try that
