Re: Most HP for a 440 Six Pack on the street?
[Re: mk2]
#1001773
05/29/11 10:14 AM
05/29/11 10:14 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Will you be using the stock stroke?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: mk2]
#1001774
05/29/11 10:22 AM
05/29/11 10:22 AM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Depends on what you consider "stock". Bub at Burtonsville Machine in Burtonsville, MD builds NHRA class record holders for a customer.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
[Re: gtx6970]
#1001777
05/29/11 11:17 AM
05/29/11 11:17 AM
jbc426
West Coast, USA
This is just over 700HP with a roller cam in the 700 lift range. and IMO , it's to much cam or not enough gear( it's a 4.10 Dana)
It wants RPM'S
Wow, that is a lot of cam and gear for the street.
Reasonable to me ended up being 493 inch motor with a mild .550 lift hydraulic cam'd, mechanical carb'd motor putting out a very streetable, very low-maintenance 684 hp/682 ft lbs of torque at 5500 rpm; through a 4 speed and 3.54 geared Dana getting 9 city and 12+ highway at 70mph.
Should do a bit better on the highway with Jamie's 5-speed. I can't imagine running lower gears in it, with over 500 ft lbs of torque at 2000 rpm it just doesn't need it.
[Re: mopar346]
#1001779
05/29/11 12:03 PM
05/29/11 12:03 PM
Posts: 2,592 None
71rm23
None
It wants RPM'S
I would love to know the specs on that build if you don't mind.
PLEASE both of you, do tell ![](/ubbthreads/images/graemlins/drool5.gif)
[Re: jbc426]
#1001780
05/29/11 12:25 PM
05/29/11 12:25 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
mine seems to run pretty good with goos street manners, shooting for 11.5-7 next weekend. .030 over 440, h-beam rods, ross pistions (11.19:1), Ported Stage VI heads, comp cams 588 solid roller, stock 6-pack with 70 jets, 35 squitters, puprle springs, Fluidampr, headers, 3800 stall, TA man valve body and 3.91's. Car flat out blows the M&H's off thru 2 gears...I'm sure I'll have to do some track tuning but it idles at 1000 and pulls about 7-9 of vacuum and crusies at 17. I'm sure if you have deep pockets you could easily get 650 or more. Chris (440Pursuit) had a nice 509 cammed 440 set-up running 11.80's in a 67 GTX.
[Re: 71rm23]
#1001781
05/29/11 12:52 PM
05/29/11 12:52 PM
Posts: 21,551 It's a dry heat
gtx6970
It's a dry heat
Looks like I was wrong,I thought the cam was in the 700 " lift range. But after looking back thru this thread,It appears to be more in the high 600" lift range. Idle quality seemed the best about 1050-1100 rpm range. Anything less and it got kinda choppy, almost acted like it was starting to load up. And anything less than 40 mph in 4th gear,and it was on the cam to much and got kind of jerky. To be honest, I only drove it maybe 3 or 4 miles total before taking it home. But I could tell it was going to be a monster and it really wanted to be in the upper rpm range. I can say it sounds REALLY REALLY good . My hats off to the builder.
Engine specs here ---> https://board.moparts.org/ubbthreads/show...part=1&vc=1
[Re: gtx6970]
#1001782
05/29/11 01:09 PM
05/29/11 01:09 PM
quick77rt
Parts Problem
Parts Problem
Good post but a bit of a trick question, its pretty clear the 3.75 stroke has been set but there are so many other possible combos. I would ask myself why on the 3.75 stroke?? In small blocks they love the 4.00 and 4.250 stroke so I figure that would bounce over to stroked BB six packs. Na/Spray...if the 3.75 is the only "rule" I bet there are some really strong combos around. ![](/ubbthreads/images/graemlins/apimp.gif)
[Re: mk2]
#1001786
05/31/11 01:42 PM
05/31/11 01:42 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
Wow! Now I have much more to think about. I am looking at 600hp 600 torque or there about. As far as manifold, Cams etc. I started this thread to see what works best in this application from you guys that have been there and done that. All the suggestions will help greatly as I am in the Military and never have the garage space and tools (cherry picker etc.) on hand to constantly build or maintain, I always have to be methodical and lay that stuff on ahead of time. I like the examples always appreciate any and all advice.
This setup is 591hp at the flywheel and is fun on the street
[Re: Colin Frolick]
#1001788
05/31/11 10:16 PM
05/31/11 10:16 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
jcb426, I would really love to know the specs of your build including parts used work performed, head specs might be a little much to ask but that is where you can make or brake a combo. PM me if you don't want it public and I will keep me mouth shut. I promise. Really.
Careful, your character's showing!
