Re: 5.2 EFI last piece
[Re: ralphie361]
#1001102
05/28/11 08:23 AM
05/28/11 08:23 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Does anyone know of an 8 pulse per revolution hall effect speed sensor with a pass thru for a speedo cable? I have a 16 pulse autometer one in the car now, and it cuts off fuel at 55 mph with the stock pcm. Had to borrow the mp computer out of my dakota, wich has no speed cut out. The system is a 95 dakota 5.2EFI in a 68 fury, the build was on the forum a couple months ago. This last piece is driving me nuts!
Just disconnect the speed sensor.
[Re: ralphie361]
#1001104
05/28/11 03:09 PM
05/28/11 03:09 PM
gdonovan
Oakdale CT
I actually ran it without one to start because I didnt think I needed one, but the pcm uses it with brake pedal sense to adjust the idle speed. The car ran ok, but on closed throttle decel it would stall intermittently, without brake pedal sense it kind of thought it was doing a stall speed test all of the time! This is my first efi swap so I am learning as I go.
The PCM on some car looks for a reduction of speed along with the brake pedal input to see if the car is slowing down.
When it sees these two events it starts raising the idle speed to prevent the car from "flaming out" when coming to a stop.
You can get around it to some degree by raising the base idle speed (usally hiding under an anti-tamper cap) a half turn or so.
This will cause more air to come in at idle around the blades rather than the AIS motor passage and help the problem.
[Re: ralphie361]
#1001107
05/28/11 10:18 PM
05/28/11 10:18 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
you can find an 8-pole vss on 84-90 YJs and 87-91 Wagoneers Just found this chart, the PPR spec is pulses per revolution.. http://www.magsensors.com/vssapps.html
